Go to Post Someone once told me, "A smart man learns from his own mistakes, but a wise man learns from the smart man's mistakes." . - Pavan Dave [more]
Unread 15-01-2016, 02:50
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
SmartDashboard Crashing
Is anyone else having trouble getting the 2016 installed SmartDashboard to stay loaded? My SmartDashboard is crashing upon loading (including when opening from the wpilib/tools directory). I'm not sure where to locate any logs about the problem. Old 2015 versions of SmartDashboard work (but won't interface with the latest DS) and the SFX/RobotBuilder apps load fine.
If anyone ran into this problem and have any troubleshooting ideas to try, let me know!
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 15-01-2016, 04:19
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: SmartDashboard Crashing
The first troubleshooting step would be to run it from a command prompt so you can get a crash backtrace:
1) Run cmd.exe. This should open a command prompt to your home directory (C:\Users\...).
2) "cd wpilib\tools"
3) "java -jar SmartDashboard.jar"
This should start up SmartDashboard with console output, printing things like "No Extension Folder" and "platform: /Windows/amd64/". When the crash occurs, you should get a backtrace or at least something output... and post it here!
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 15-01-2016, 22:41
seg9585's Avatar
AKA: Eric
Hi Peter, nice to hear from you.
See attached image. It appears to have to do with loading the widgets. Would this indicate an issue with my Java install? Do I need to install an update to a plug-in? (I already downloaded all the FRC java plugin updates)
http://www.chiefdelphi.com/forums/at...d=14529154 50
My FIRST legacy:
Unread 15-01-2016, 23:43
Did you install the plugins released today? It had a change that may fix this.
Unread 16-01-2016, 00:05
seg9585's Avatar
AKA: Eric
Resolved! Yeah today's plugin updated fixed it! Thanks for the heads up.
My FIRST legacy:
