Skyway Wheels with AM14U3
Due to the lack of availability of the AM Pneumatic wheels we are thinking about turning to Skyway for substitutes.
Does anyone have experience using any of their wheels with the AM14U3? Ordering options located here I am not sure about their Beadlock tires does anyone have experience with these? Any tips for mounting their tires? What other parts would I need in addition to the parts listed on the upgrade kit? |
Re: Skyway Wheels with AM14U3
First off, call them and tell them you're with a FIRST team. There's a discount.
Second, from what I remember of the Beadlok tires, they're not pneumatic, they're solid rubber. I think it was also rather harder and less grippy than you'd really like for an FRC application. |
Its really sad that there is a shortage of pneumatic wheels. No fault to the supplier. To have to go with a less than optimal alternative, if that ends up being the case with robot testing......oh boy.
What do you want to know about the SkyWay wheels? We use an all gear drive for them but it could easily be done with chains.
It's a crazy world out there. |
I think what Oblarg is getting at is that because AndyMark has been in the loop about game elements before Kickoff in the past, FIRST could identify potential supply issues and notify AndyMark, and maybe even others select retailers, in advance. There are quite a few difficulties with that, but it is an option.
#9
Speaking for only myself not anyone else....
It's not actually that hard to fabricate wheel hubs. I could understand the issue if a team was in dire need of basic shop tools. I could understand the time might be more valuable if you could buy them. Well you can't buy them fast enough - so why not try to make them? Is it really more practical to gripe about it? What's the worst that happens you fail to do it right, or would you rather, risk not getting it done? I am actually way more surprised that someone hasn't risen to the challenge and started posting examples of making wheel hubs. I suppose some people want to weed out their competitors like this. Last edited by techhelpbb : 15-01-2016 at 23:56. |
#10
I don't think it's unreasonable to think that with knowledge of the game, the demand for the pneumatic wheels and for the treads could have been predicted. Running out of stock is one thing. Running out of stock on the first weekend of build season every single year is something else. If you think it is actually impossible to do better than this, then I'm very much open to hearing why. You don't have to be snarky about it, just make your point. Last edited by Oblarg : 16-01-2016 at 00:03. |
#11
As far as I recall from interviews with Andy - they do not have that much time. (Memory could be fuzzy though).
#12
I don't have experience mounting skyway wheels to a AM14U3 but we have mounted the wheels to sprockets in the past. Its a pretty easy, all it requires is a spacer and some bolts. I'm sure something similar can be done with the pulleys for the AM14U3 chassis. |
#13
I know you guys like to turn them down and cut your own pattern into them. How do you do this and how does this affect the performance of the wheels? How does the traction of these wheels stand up to the rubber of typical pneumatic wheels on carpet and lexan? I know they have urethane tread, but that comes in a variety of hardnesses and these seem to be on the hard, low CoF side. I'm wondering if it's worth pursuing using these in the rear for their traction advantage in conjunction with pneumatic tires for absorbing impacts in the front. Thoughts? |
#14
Not to mention that there is probably a significant lead time on the initial orders they make to the manufacturer(s). Sure tons are probably made by said company every day, but those same tons are already sold to existing customers... hence why the manufacturer(s) probably can't just flip a switch and instantly have the additional output (i.e. supply) to meet AndyMark's needs (i.e. demand). Industrial parts I understand are like that; the demand is usually somewhat inelastic (similar to why diesel prices don't fluctuate as much as gasoline) so the ability to change production quota reflects that; a sudden large demand isn't usually seen as likely enough to invest the additional resources to allow for it. Thus, since these wheels are (presumably) sourced by a wheel company or two, they're happy to sell AndyMark the components but the amount (either gross number of components or a given production rate) takes some time even if it's a part already in production. Other food for thought: I remember in 2014 during Lunch With Andy that he always mentioned shipments coming in for the balls from Sportigo in a similar fashion to the shipments for pneumatic wheels/rhino plates/treads (only w/o the crazy shortages) which also seems to suggest AndyMark isn't given as much advance warning as many seem to think. |
#15
![]() If we press in a modified AM Hub, do you think there is enough material in the area of the screwholes to tap or drill through to bolt on the AM sprockets? Pls excuse rough 'CAD', it was scaled off Skyway Drawing. I don't suppose anyone has a better cad file? |
