Go to Post As an adult who has spent years working with youth in Boy Scouts and FIRST, and on behalf of all other adults at the event: deodorant. - Rick TYler [more]
Unread 16-01-2016, 11:11
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
XL-Maxsonar-EZ mb1443 Programming Help
We acquired a mb1443 rangefinder from FIRST Choice. The mb1443 rangefinder uses a micro-USB output. When using the sample java code (found at: https://wpilib.screenstepslive.com/s...e-to-a-surface) we received this error:
Unhandled exception: edu.wpi.first.wpilibj.util.AllocationException: Digital input 1 is already allocated at [edu.wpi.first.wpilibj.DigitalSource.initDigitalPor t(DigitalSource.java:36)
The screensteps for rangefinders states that if you are using serial there are no classes provided by WPI to handle it. Am I mistaken in believing that that means we will not be able to use a USB rangefinder without creating our own class? If I am mistaken, how would we fix the error we are receiving? If I am not mistaken, how would we even start creating our own class for such a thing?
Thanks in advanced,
Marcel
3539 Programming Lead
The Programming Lizard
Unread 16-01-2016, 14:08
Re: XL-Maxsonar-EZ mb1443 Programming Help
I'm pretty sure you didn't get that sensor from FIRST Choice.
You are correct, you have to write your own class.
Unread 18-01-2016, 17:16
jagow100's Avatar
I'm bumping this thread.
