Go to Post NO MORE "COTTON EYE JOE"!!!! - hipsterjr [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 13-01-2016, 18:41
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
How to get image from Axis camera to a Python program?
Hello, I would like to be able to get the stream of from the axis camera plugged into the router into a Python program so I can perform some image processing on it with OpenCv.
How would I got about doing this? And is there any example code?
Unread 13-01-2016, 19:02
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge is on a distinguished road
Re: How to get image from Axis camera to a Python program?
I'm not sure this is a full answer but...
You can use a lot of OpenCV image manipulation features by way of the recently-released GRIP. I've been playing with this and it's really slick. Powerful, easy to use, and written in Java so it will run on a DS, RoboRio, or other onboard processor. It can output to NetworkTables, which puts the data in easy reach of any Python program.
Another similar option is RoboRealm. Every team gets a code for a free license (see your TIMS). It's also easy and powerful, writes to NetworkTables and even lets you run Python code right inside the app. We did exactly that with an Axis in the 2014 game to identify the hot goal during autonomous. The only downside is it's a PC-only app, so you'll need to do processing on your DS or similar onboard computer.
Hope that helps.
Unread 13-01-2016, 19:09
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
This is the code from a demo I did with my team a while back.
https://github.com/dawonn/HelloPythonOpenCV
I highly recommend that you record videos of interest and then develop your algorithm with the videos. It will save you a lot of time and effort. Then once you think the vision system is working, link it to your robot and let it rip.
Unread 13-01-2016, 21:59
JohnM's Avatar
FRC #5854 (Glitch)
Yes will do. Thanks. Will test this tomorrow.
Unread 14-01-2016, 00:04
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Our OpenCV code from last year running on the RoboRIO: https://github.com/frc1418/2015-vision
You will need to install OpenCV to use it, see https://github.com/robotpy/roborio-opencv
Unread 14-01-2016, 23:05
JohnM's Avatar
FRC #5854 (Glitch)
Okay I got some code to work that I found someplace else. Here's what I have.
import cv2
import urllib
import numpy as np
stream=urllib.urlopen('http://10.58.54.108/mjpg/video.mjpg')
bytes=''
while True:
    bytes+=stream.read(1024)
    a = bytes.find('\xff\xd8')
    b = bytes.find('\xff\xd9')
    if a!=-1 and b!=-1:
        jpg = bytes[a:b+2]
        bytes= bytes[b+2:]
        i = cv2.imdecode(np.fromstring(jpg, dtype=np.uint8),cv2.CV_LOAD_IMAGE_COLOR)
        i = cv2.cvtColor(i, cv2.COLOR_BGR2HSV)
        cv2.imshow('i',i)
        if cv2.waitKey(1) == 27:
            exit(0)
My question I have now is that does the rest of my code for my program go in that while loop? I don't think I clarified in my other post that this program will be running on the driver station.
Unread 15-01-2016, 00:29
virtuald's Avatar
RobotPy Guy
Yes, you would put your code in that loop. But... I wouldn't use that code, it's not going to be particularly efficient.
You might want to try this instead: https://github.com/frc1418/2015-visi...mjpg_client.py
Unread 16-01-2016, 11:47
JohnM's Avatar
FRC #5854 (Glitch)
Great! Although could you provide a simple example of how to implement this?
Unread 16-01-2016, 11:49
virtuald's Avatar
RobotPy Guy
Look at the files next to it?
