Go to Post If you look at where you have come from you can often tell where you are going. - Turtlecoach [more]
Unread 16-01-2016, 12:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Motor Comparison Chart
I think the most valuable data is the 3 minute max power and the stall torque curves. Pretty interesting that the "high power" 775s lose to mini-CIMs after just 10 seconds. They probably lose even faster if you're accidentally on the wrong side of peak power.
Unread 16-01-2016, 16:21
FRC Warrior FRC Warrior is offline
FRC #4169
FRC Warrior is an unknown quantity at this point
Why do 775 Pros drop max power so suddenly?
Unread 16-01-2016, 17:13
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
The 775Pro's are intended for shooters and such, where they can run at high rpm. They are fan cooled, so if they stall they fry in 4 seconds.
