Go to Post Be the change you want to see. - staplemonx [more]
Unread 15-01-2016, 09:00
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Frame Perimeter when climbing tower?
In practice the Frame Perimeter rule is more enforced by RI's than the Ref's. The Ref's are not about to take out a tape measure and walk onto the field during play. The RI's will check for maximum extension during the inspection process. They will look at the robot as it is sitting on the ground.
Unread 15-01-2016, 09:25
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Not really. Just because an appendage CAN extend beyond 15" doesn't mean that it WILL.
Former Mentor Team 1771
Former mentor Team 4509
Unread 15-01-2016, 09:35
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Correct.
Many Head Refs ask the LRI to provide a list of robots (based on inspection) that are mechanically capable of extending beyond what the game rules allow, so that refs can be advised to watch at critical moments when one of those robots is playing.
Whether the robot actually does extend too far during a match is a call for ref to make. If a ref sees it happen, the infraction should be called.
Richard Wallace
since 2003
Unread 15-01-2016, 09:52
philso philso is offline
FRC #2587
Originally Posted by MrBasse View Post
I like this rule. It's just like climbing in 2013, the cylinder made it tough, then they made that cylinder move with the robot and it got a lot easier. This time the perimeter moving with the robot actually makes it harder. Remember, this is an engineering challenge. If scaling were easy, everyone would do it and nobody would be impressed. But now, it is just complicated enough that you can't just toss a hook up there and winch yourself up. Good work GDC, good work.
To the OP, what combo of cylinders were you planning to use to curl yourself 90 degrees?
Yes! This is why it is "The Hardest Fun You Can Have". If it was so easy that everyone can climb to the top of the pyramid in 6~7 seconds like 254 did in 2014, how inspirational would any of this be?
Originally Posted by Richard Wallace View Post
Correct.
Quite a few people posting on this thread have indicated that it should not be necessary to extend more than 15" beyond the frame perimeter to scale the tower. If a team verifies for themselves that this is true and has a mechanism that can extend beyond the 15" limit, it might be a good idea for them to add a mechanical limit. It is usually a good idea to "just not attract the attention of the Authorities" in the first place.
Unread 15-01-2016, 14:13
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
The length of the robot makes no difference. You also do not need to touch the wall of the tower as in your sketch, just reach over the rung.
Not sure why you think that. The sketch below demonstrates the longer your wheel base is, the easier it will be to stay within the 15" rule while attempting to scale.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 15-01-2016, 14:40
Oblarg Oblarg is offline
AKA: Eli Barnett
Originally Posted by EricLeifermann View Post
The rung you are grabbing onto is not flush with the tower walll. It sticks out, everyone should be well with in the 15 in limit when grabbing the rung. Now how you pull up your robot to stay with in the rules is another matter.
You may well want to use the face of the tower as a guide for your mechanism to ensure it grabs the rung.
Note that, as per the math I posted earlier, this should be possible without exceeding the limit. But you have to be careful, since it will be close.
"The breakfast of champions!"
Unread 15-01-2016, 14:53
Jared's Avatar
Jared Jared is offline
The ramp on the batter is 48" long, so I don't think many teams will have robots contact the carpet while they are grabbing a rung.
Unread 15-01-2016, 14:59
martin417's Avatar
AKA: Martin Wilson
So, you plan to build a robot that is excess of 48" in length? Then you will be less than 12 inches in width. I doubt you would make it to the tower before you fell over, so climbing becomes a moot point. I should have said that
"within the design constraints of a reasonable robot that can play the game, length makes no difference."
Unread 16-01-2016, 00:12
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Thanks for all the support guys, glad I asked. This is going to be a heck of a game for the refs to keep track of.
Unread 16-01-2016, 00:59
AKA: Eli Barnett
Honestly, I hope the refs have some device for measuring this if they're going to be strict about calling it, because there's absolutely no way that anyone is going to be able to discern with their naked eye whether a ~6' tall climbing extension is angled just enough to be violating this rule.
If this is called purely by eye, either nothing close will be called or there will be a lot of wrong calls.
Unread 16-01-2016, 12:51
Robosparks2926's Avatar
Robosparks2926 Robosparks2926 is offline
FRC #2926
Robosparks2926 is an unknown quantity at this point
Question Re: Frame Perimeter when climbing tower?
can the wheel protrude outside the wheel base?
Unread 16-01-2016, 13:11
cpapplefamily cpapplefamily is online now
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
I have been modeling this as well. Seems to me that if the front of your frame projected to the ramp is < 6.3" from the wall face any reach for the bar should adhere to all the rules of 15" beyond the perimeter during the reach. How your robot folds up during the lift is up to you. If only reaching for the bar you can be < 10.5" Your reach should be ok.
I modeled with the Team Prints for the Chin up bar.
Unread 16-01-2016, 14:33
GaryVoshol's Avatar
Cogito ergo arbitro
Please clarify your question. There is no definition of "wheel base" in the rules. So we go to the real world definition of wheel base, and it's defined as the distance between wheels. Actually it's center-to-center distance. So you can look at it, that your wheels are always outside your wheel base (the leading and trailing parts of the wheels).
(since 2004)
Unread 16-01-2016, 15:16
Rookie Year: 2015
Originally Posted by mockingod View Post
Note: I understand that the rule is possible to change.
I showed my teammate this thread and tried to explain it to them and they couldn't really understand what rule you guys were exactly debating so I made crappy cartoon diagram in MS paint that might be useful if you're ever debating with a teammate about this rule for whatever reason.
http://i.imgur.com/SIZCRUt.png
(I don't think the rule is super dumb. I don't think any rules are dumb, rules are rules. I just put that last bit in there for laughs by my team)
Saving our reveal till an appropriate time but I'm confident we have this. Hope they leave the rule alone
Unread 19-01-2016, 19:39
For ten points?
