Go to Post I think I'm going to need a 12 step program to help cure me from my Cryptic Dave Lavery Chief Delphi Post Analyzation Disorder I got goin' on here. - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 14-12-2014, 18:56
Re: Robot Builder?
Originally Posted by 2130Pi View Post
I'm no team 2130 and we have a problems with robot builder. On one of our computers that is for programming robot builder wont even open or do anything. Our "Lead Programmer" says its a problem with java but we don't know. And I haven't been able to find anything on our problem. So if you have had the same please comment and maybe we can figure it out. thx
Try running it from the command line, java -jar <robotbuilder jar file>. See what it reports.
Unread 16-01-2016, 13:47
RugnarStormBorn RugnarStormBorn is offline
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
RugnarStormBorn is an unknown quantity at this point
Re: Robot Builder?
So...thread necromanceries here but when I try executing RobotBuilder from the command prompt we get "Error: Unable to access jarfile RobotBuilder.jar"
Unread 16-01-2016, 13:52
Re: Robot Builder?
Are you in the same directory as RobotBuilder.jar?
Unread 16-01-2016, 14:09
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Re: Robot Builder?
Whelp, that would've undoubtedly helped...guess I shouldn't do this stuff when I'm half asleep. XD
But still...nothing opening, do you want me to post what the cmd prompt came up with?
Re: Robot Builder?
Yes
Unread 16-01-2016, 14:15
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Re: Robot Builder?
C:\Users\jones\wpilib\tools>java -jar RobotBuilder.jar
Extension components: []
Adding extensions for section: Hidden
Adding extensions for section: Subsystems
Adding extensions for section: Controllers
Adding extensions for section: Sensors
Adding extensions for section: Actuators
Adding extensions for section: Pneumatics
Adding extensions for section: OI
Adding extensions for section: Commands
Exception in thread "AWT-EventQueue-0" while scanning for the next token
found character '\t' that cannot start any token
in "<reader>", line 3, column 1:
<static-widget class="edu.wpi.f ...
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchMoreTo kens(ScannerImpl.ja
va:413)
at org.yaml.snakeyaml.scanner.ScannerImpl.peekToken(S cannerImpl.java:247
at org.yaml.snakeyaml.parser.ParserImpl$ParseDocument End.produce(ParserI
mpl.java:264)
at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(Par serImpl.java:160)
at org.yaml.snakeyaml.parser.ParserImpl.getEvent(Pars erImpl.java:170)
at org.yaml.snakeyaml.composer.Composer.composeDocume nt(Composer.java:12
4)
at org.yaml.snakeyaml.composer.Composer.getNode(Compo ser.java:84)
at org.yaml.snakeyaml.constructor.BaseConstructor.get Data(BaseConstructo
r.java:104)
at org.yaml.snakeyaml.Yaml$1.next(Yaml.java:501)
at robotbuilder.robottree.RobotTree.load(RobotTree.ja va:387)
at robotbuilder.robottree.RobotTree.load(RobotTree.ja va:361)
at robotbuilder.MainFrame.openDefaultFile(MainFrame.j ava:141)
at robotbuilder.RobotBuilder.lambda$main$85(RobotBuil der.java:44)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessI mpl.doIntersectionP
rivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Unread 17-01-2016, 16:32
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Re: Robot Builder?
I have a theory on what's going wrong for you. When RobotBuilder starts up, it tries to load the robot configuration file it was working on previously. The name of the file it was most recently working on is stashed using Java's Preferences utility. I think that on your system it is mixed up, and is reading a file that is isn't a valid RobotBuilder YAML file.
If we clean out RobotBuilder's preferences, then it should revert to opening up a blank robot configuration.
Unfortunately, I don't know that there is anything in the RobotBuilder code to self-correct on this subject. Java preferences are stored in different locations for each different operating system. Macs keep them in PLIST files in the user Library. I think Windows stashes them in the registry. Linux has its own set of files.
The simplest solution I can think of is to run a short Java program that cleans out the RobotBuilder preferences. Try compiling and executing the following. It won't do any harm to your system:
import java.util.prefs.Preferences;
public class PreferencesCleaner {
	public static void main(String[] args) throws Exception {
		Preferences prefs = Preferences.userRoot().node("robotbuilder.MainFrame");
		prefs.clear();
Unread 19-01-2016, 13:25
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Robot Builder?
The old or corrupted preferences or previous save file seems like it might be your problem. Have you gotten past the issue you were having?
Brad Miller
Robotics Resource Center
Unread 20-01-2016, 20:04
User of the Matrix
AKA: Michael Brooks
FRC #2130 (Alpha+)
Re: Robot Builder?
		prefs.clear();
This fixed it! Thanks a million!
Unread 02-05-2016, 09:10
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: Robot Builder?
Wow.... just watched the Robo Builder overview videos from Brad Miller and i am excited...
Can this be use for both FTC and FRC?
We are a rookie team, we depended on one programmer last season and he did good with labview with no experience, unfortunately he is leaving for college and we are starting our programming team from scratch.
Many teams recommended going to JAVA as it would be a much easier programming language to ;earn for beginners and there is tons of ways for the students to learn it... I am still not totally sold as Labview seem to have some great material online too...
And then i found this thread... I really like what i seen in the video... just trying to wrap my head around where to start and how much of a learning curve is it going to be...
Our programmers will most likely work on both the FTC and FRC robot next season and beyond !
Any input would be appreciated...
