Go to Post I know my grandmother would call me a bully for that. And she didn't raise a bully. - Libby K [more]
Unread 16-01-2016, 14:49
tyler9698's Avatar
tyler9698 tyler9698 is offline
AKA: Left Hook
FRC #5624 (Tiger Tech)
tyler9698 is an unknown quantity at this point
OM5P-AN Radio Trouble
Our programming team is having trouble configuring the radio. The specific error is :
Bridge Programming Sequence Failed
Failed to change IP address, please check for an adapter with the address : 192.168.1.51
We have already changed our sharing settings, switched our Ethernet, and ran the program as an administrator.
Unread 16-01-2016, 14:56
LogicParadox LogicParadox is offline
FRC #5754 (Brooks Academy Robotics (BAR))
LogicParadox is an unknown quantity at this point
Post Re: OM5P-AN Radio Trouble
What type of power supply are you using? Because ours would not work because we where using a 5 volt power supply and this radio requires 12 volts.
Unread 16-01-2016, 15:05
tyler9698's Avatar
AKA: Left Hook
12 Volts
Unread 16-01-2016, 15:55
That error message means the PC being used either will not let it's IP address be changed (can be blocked by third party security tools) or the IP address is already assigned to one of the other PC existing network adaptors.
Try Disabling all other network adaptors and leaving only the Local Connection 1 Enabled, and try changing the IP address (to 192.168.1.51 ) by hand to see if it gives you an error message.
Unread 16-01-2016, 20:12
tyler9698's Avatar
AKA: Left Hook
I already changed the IP on my ethernet, but didn't disable my other adapters. Will see if disabling does anything tomorrow.
Unread 16-01-2016, 20:24
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Even if you disable the other adapters it will still throw that error because an adapter is using that IP. Go into the ipv4 settings of every adapter and make sure that they all have a dynamic IP
Unread 17-01-2016, 09:16
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
We were having the same issue and turning off our wireless adapter fixed the issue (we only had two adapters, wireless and ethernet)
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 17-01-2016, 18:17
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
I also had an error configuring the radio (not sure if it was the same one or not). Then, I tried updating the firmware first, and then it worked.
Head Programmer / Driver
Unread 17-01-2016, 20:20
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
If I remember correctly (I might not), the new radios don't come with firmware by default, and you have to load the firmware yourself. There's a guide somewhere that tells you how to do it.
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
Unread 17-01-2016, 20:29
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Radios recieved in the KOP are already flashed with the FRC firmware and should not need to be re-flashed, proceed to the next step.
From the Screensteps guide for configuring the radio.
Unread 17-01-2016, 20:37
tyler9698's Avatar
AKA: Left Hook
This was the KOP radio, so it should be already flashed.
Unread 18-01-2016, 11:21
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
I had the same issue. This is what I did to fix it.
http://www.chiefdelphi.com/forums/sh...d.php?t=141688
There was also lots of rebooting.
Unread 18-01-2016, 13:19
tyler9698's Avatar
AKA: Left Hook
Disabled the othe adapters and got it to work. 4 hours of stress later I can finally use wifi.
Unread 18-01-2016, 13:34
Only 6 more weeks of stress plus intense stress during competition left to go
