Go to Post And when I heard the word "Mentor Round" - you had me SOLD. - Chris is me [more]
Unread 16-01-2016, 20:49
RamTech 59 RamTech 59 is offline
RamTech 59
FRC #0059 (RamTech 59)
RamTech 59 is an unknown quantity at this point
Arduino Input to Java Code
Is there any way to read Arduino usb input through Java code and passing it to the RoboRIO with the 2016 software?
Unread 16-01-2016, 21:44
AndyB871 AndyB871 is offline
FRC #0871
AndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura about
Re: Arduino Input to Java Code
Sure, You can use the MXP serial port, onboard serial port, USB-Serial, I2C, SPI,
The list goes on. Since you said USB input, I'm assuming you mean usb-serial. We're having issues with the roborio code crashing when we do _anything_ with usbserial, but it should be relatively simple for you to try using the onboard RS232 port on arduino channel 0
Take a look at the SerialPort class in the wpilib
Unread 17-01-2016, 16:08
RamTech 59
Thank you, I'll look into it.
