Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Unread 16-01-2016, 20:56
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
How to put two motors on one spike
So my understanding is you can put two motors on one spike (Please tell me if I'm wrong), but I'm not sure how. I think just putting two wires in one crimp connection is the answer, but after reading about it online I saw a diagram to connect the power negative and the motor negative to the same, and just hook up the positives to the motor leads on the spike. Can someone help me figure this out?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 16-01-2016, 21:06
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: How to put two motors on one spike
Spikes are relays, they are for things that go on and off. Motor controllers drive motors and it's one motor per controller. So if you have 6 motors you need six Talons (for example) The rules go over this pretty clearly.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 16-01-2016, 21:13
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
R53 has the rules on this. Some motors can be on a spike and have two per controller. A senior mentor informed me that two Sims can be on the same controller if they are inputs to the same gearbox with one output. Is this true? The gear box output shaft is the single load?
Unread 16-01-2016, 21:19
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
The Spike can be used to control certain motors if you don't need throttle, just on/off, although per table 4-4 in the rules, you can only legally control 1 motor with 1 spike, in which case you wire M+ to the motor's positive and M- to the motor's negative.
WITH THAT SAID
Outside of the competition, you can in fact control two motors separately with a Spike. Wire one to the M+ and another ground somewhere, and the other to M- and some other ground.
SEE: http://content.vexrobotics.com/docs/...uide-sep05.pdf
EDIT: @cpapplefamily: A regular motor controller can support 2x of the motors that a Spike can support 1x of. You can never have 2x motors on a Spike. Additionally, a CIM is not one of the motors listed as being able to run 2x of on a proper motor controller. Furthermore, you would never want to, because that one motor controller is still limited to the same 40A breaker, which 2 CIMs could pop in a heartbeat.
What CAN be done, which I believe your mentor may have confused with what you wrote, is that you can have 2 motor controllers on one PWM signal, using a Y cable and 1 PWM port on the RoboRIO.
Unread 16-01-2016, 21:27
See rule R53 and table 4-4 for the details.
Unread 16-01-2016, 21:30
Rookie Year: 2015
Thanks for clearing that up Y-cable the PWM to two Motor Controllers.
I see now that Spikes(Relay) depicts 1 motor, Motor Controllers allow 2 smaller.
