Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Unread 16-01-2016, 13:38
isaacaddis's Avatar
isaacaddis isaacaddis is offline
FRC #0687
isaacaddis is an unknown quantity at this point
Dimensions of Field?
Has anybody found the distance between the Outer Works and the edge of the tower as marked by "x" is in the figure?
Thanks
Unread 16-01-2016, 17:22
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Re: Dimensions of Field?
While that value isn't explicitly given in the manual, its easy to find by subtraction. If you can't do that math then good luck building a robot.
Unread 16-01-2016, 22:03
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
As best I can tell, it is about 135". I took this based on the line you made and referenced the field at the nearest feature.
Unread 18-01-2016, 05:44
protoserge's Avatar
OP, Did that help you? Do you need a different measurement?
Unread 19-01-2016, 09:37
HolyHacker335 HolyHacker335 is offline
FRC #4945 (Titanium Wrecks)
Rookie Year: 2015
HolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud of
Look here: https://firstfrc.blob.core.windows.n...Components.pdf
for the tower and batter dimensions and then throw in the field element distances and that should get you what you want.
