Re: 2363 Triple Helix week one prototypes
This testing was primarily to see if our standard drop would work, or if we were in for a redesign. The tire pressures are whatever they ended up when pumping up with a hand bicycle pump. Next step is to use a compressor with a real pressure gauge. We'll play with the pressures in the center vs outside wheels to see how that effects the current draw when rotating in place. I can confirm that these wheels definitely scrub more than Colson wheels. We have Colsons on the way, too, and could switch to those, but we're liking the shock absorption of the pneumatic tires.
![]() Yeah, we tried the hard rubber first and I don't think many of us were fans. I have a couple reservations around us diving headfirst into the school of WCD design for this years drivetrain. The ability to absorb shock with those wheels and a couple other mechanical tricks we are looking at to assuage my fears should do the trick. We did some of this work too, but I'm pretty sure the only video anyone got today was me eating chili near the drill press. Also our 2012 wheeled shooter is in a cold dark circle of hell along with our MK Is for 2013 shooter actuation, 2014 drive, and 2015... everything. We're kicking around some blue sky plans to solve the inevitable ball consistency problem; I can only imagine the damage some robots are going to inflict on them this year. |
Looking good. I liked the use of a larger wheel for a flywheel on the shooter.
How much compression did you stick on the shooter? |
Have you tested that drive base on the moat? Our initial pre-built concept chassis had a similar wheel spacing and we just got caught up. We thought the rock wall would give use the biggest problem, but the spacing of the moat can cause the chassis to sit on the moat ends and have the wheels free spinning. The rock wall was no problem. The moat was deceptively challenging for us. Our new prototype robot will have the wheels closer. Hopefully, our new spacing will be perfect and we can use that spacing for building the next two robots (practice and competition).
Here's our video of this. Last edited by bEdhEd : 17-01-2016 at 05:37. |
This looks great! May I ask what amount of center drop you have on the drivetrain, , what diameter the Colson shooter wheel is, and how much you are gearing up the CIM?
#8
![]() <edit> Oops. Looks like Nate has no such compunctions... I will say that the prototype drivetrain is from our 2014 robot, and we plan for the 2016 drive rails to be of the same design as the 2015 drive rails. The CAD for these bots can be downloaded from FRCdesigns.com Last edited by ToddF : 17-01-2016 at 15:43. |
#9
For instance, hit the mote with a bit more authority and you may just own it. |
#10
I tend to agree. This year, different from years past(specifically 2010), you need to launch yourself at a few of the defenses just to get over them.
#11
We believe true authority is being able to traverse any defense at any speed, even at a crawl haha.
#12
That's one consistent (at from the video) shooter!
#13
We're thinking about drown-down pads (or similar) to assist in stability and angle adjustment for high goal shots. Strategic placement could also mean they assist with getting stuck in the moat. Our prototyping drive base didn't get stuck unless it skewed far left/right, but that base was also 3" too long w.r.t. the current actual CAD design.
#14
