Go to Post Don't trust everything you read on Chief Delphi. - Peter Matteson [more]
Unread 16-01-2016, 21:58
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
2363 Triple Helix week one prototypes
It was a good week of prototyping. We took a previous year's drivetrain and replicated the wheel spacing we planned to use this year. With AndyMark 7.65" diameter wheels we can handle both the defenses we've had time to build. The drivetrain shown has a crate of CIMs strapped on top to give a total robot weight of 121 lbs. Yes, it is top heavy, and yes a rookie driver tipped the bot, and yes, the tote shattered.
The shooter prototype was slapped together to let us know if a wheeled shooter showed any promise.
Here's video of some prototype testing this afternoon.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 16-01-2016, 22:07
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: 2363 Triple Helix week one prototypes
Todd, have y'all played around with the drop or pressure on those at all?
Unread 16-01-2016, 22:10
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Looks great! Mind sharing what wheel base and wheel track you're showing? We've been trying to figure out the best spacing but we haven't seen a traverse as clean as that.
Unread 16-01-2016, 22:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It seems like your top heaviness is probably helping you over the rock wall. Keeps you wheels up longer so the front ones hit the wall at a better angle. I'd be interested how things work with a lower CoM closer to what you'd normally be running.
Also I probably don't have to remind you that shooting a single brand new ball consistently does not make a consistent shooter.
Unread 16-01-2016, 22:35
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
This testing was primarily to see if our standard drop would work, or if we were in for a redesign. The tire pressures are whatever they ended up when pumping up with a hand bicycle pump. Next step is to use a compressor with a real pressure gauge. We'll play with the pressures in the center vs outside wheels to see how that effects the current draw when rotating in place. I can confirm that these wheels definitely scrub more than Colson wheels. We have Colsons on the way, too, and could switch to those, but we're liking the shock absorption of the pneumatic tires.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 16-01-2016, 22:38
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Nope. I'm still having PTSD flashbacks from the nightmare of trying to tune our foam basketball shooter in 2012.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 16-01-2016, 22:50
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
Yeah, we tried the hard rubber first and I don't think many of us were fans. I have a couple reservations around us diving headfirst into the school of WCD design for this years drivetrain. The ability to absorb shock with those wheels and a couple other mechanical tricks we are looking at to assuage my fears should do the trick. We did some of this work too, but I'm pretty sure the only video anyone got today was me eating chili near the drill press.
Also our 2012 wheeled shooter is in a cold dark circle of hell along with our MK Is for 2013 shooter actuation, 2014 drive, and 2015... everything. We're kicking around some blue sky plans to solve the inevitable ball consistency problem; I can only imagine the damage some robots are going to inflict on them this year.
Unread 17-01-2016, 02:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looking good. I liked the use of a larger wheel for a flywheel on the shooter.
How much compression did you stick on the shooter?
Unread 17-01-2016, 05:27
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Have you tested that drive base on the moat? Our initial pre-built concept chassis had a similar wheel spacing and we just got caught up. We thought the rock wall would give use the biggest problem, but the spacing of the moat can cause the chassis to sit on the moat ends and have the wheels free spinning. The rock wall was no problem. The moat was deceptively challenging for us. Our new prototype robot will have the wheels closer. Hopefully, our new spacing will be perfect and we can use that spacing for building the next two robots (practice and competition).
Here's our video of this.
Unread 17-01-2016, 10:44
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
That is probably the best reaction ever. "That sucks."
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 17-01-2016, 10:57
That is hilariously and horrifyingly terrible. Can't wait to see how our prototype is handling the moat when I get back to houston. Also, I'm told using steel for the 1.5x2.5 bars makes things even harder. So you might want to try that.
Unread 17-01-2016, 11:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
This looks great! May I ask what amount of center drop you have on the drivetrain, , what diameter the Colson shooter wheel is, and how much you are gearing up the CIM?
Unread 17-01-2016, 12:25
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I believe one key to some of the defenses this year is to drive you bot like you stole it.
For instance, hit the mote with a bit more authority and you may just own it.
Unread 17-01-2016, 12:39
dodar's Avatar
I tend to agree. This year, different from years past(specifically 2010), you need to launch yourself at a few of the defenses just to get over them.
Unread 17-01-2016, 13:14
Nate Laverdure's Avatar
FRC #2363
About 10%
.125"
2.5"
VexPro p/n 217-4046
1:1.21
AndyMark SpinBox
