Go to Post Power tools don't hurt people. Poorly instructed people hurt themselves, using power tools. - sanddrag [more]
Thread Tools Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Unread 16-01-2016, 22:40
swervemaster_06 swervemaster_06 is offline
Robot Configuration Specialist
FRC #6069
Rookie Year: 2016
swervemaster_06 is an unknown quantity at this point
New Rookie Team Robot drivetrain
Hey guys!! So this is my rookie year as a freshman and my team's first year, and I don't really know the FRC community that well, but here's my team'
s first attempt to really innovate and create the best possible design for this year's game: Stronghold. So here is the 5th iteration of our design that we're about to send to our sponsor's shop to get fabricated. We've already bought a 4ftx4ftx4in. block of carbon-fiber reinforced balsa that we plan to waterjet. The outer wall is a 4in high wall while the inside is 1in thick. We put cut outs were we could to reduce weight in the drivetrain. The drivetrain weight is 10.226 lbs. This innovative drivetrain makes use of our electronics to power the movement of the drivetrain. We received a large donation of parts as a rookie from an older team, and a large portion of them were old electronics. We decided to be economical, because we only have 2 sponsors right now. 1 being 7eleven and the other being an anonymous machine shop sponsor. Because of our low budget we could only obtain low-cost parts, hence the balsa and old electronics. These constraints lead us to think up a very innovative design . We have decided to mount the victor 888 motor controllers donated to us on the bottom of drivetrain, so that the blowing force from the fans can make the carbon reinforced balsa wood drivetrain hover above the ground. We found hovering to be the best possible method of overcoming the rocky terrain defenses because we would not have to sacrifice speed and time to traverse the rocky terrain like robots contacting the floor with wheels or treads would.We can now hover at a height of 2in. and hover across the field at a speed of 0.0113559 nautical miles/second. The drivetrain also only weights 10.226 lbs. . To hover we reversed the wiring so that the fan would spin back wards and would put a downward force on the floor. We also coded the victor motor controllers to spin 21.96969 times the speed they normally do to create a stronger fan propulsion source. To do this we had to replace the motors inside the fans with more powerful ones. We're really proud to present this design to the robotics community in hopes of ways to figure out how to improve this current design. We look forward to the hard fun with other teams and hope to see you at orange county regional (March 30 - April 2, 2016) and the st. louis championships!!!
Bottom View:
Top View:
Unread 16-01-2016, 22:46
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: New Rookie Team Robot drivetrain
http://www.chiefdelphi.com/media/photos/36127
Welcome to CD. We've done this before, though.
http://www.angelbotics.com
Remember why you're doing this.
Unread 16-01-2016, 22:58
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I was just talking with a fellow mentor about trying a tethered quad-copter to get our climbing hook on the bar, I think this solves all of our problems! Mounting a ridiculous number of speed controllers upside down would definitely get us the lift we need to get up there!
2016: Lake Superior WFFA
Unread 16-01-2016, 23:03
PatrickSJ's Avatar
PatrickSJ PatrickSJ is offline
AKA: Patrick Warren
FRC #3620 (Average Joes)
Rookie Year: 2015
PatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud ofPatrickSJ has much to be proud of
and instead of using 7071 Aluminum, it's carbon fiber reinforced balsa.
FRC #6069
Rookie Year: 2016
Thanks for the support fellow roboticist! We were also gonna use this design to lift us up 2 feet off the banter during the end game for 15 points! We can avoid brownouts from voltage draw due to this design using no CIMs what so ever, so we can push more volts to the fans to achieve a greater height
Unread 16-01-2016, 23:06
philso philso is offline
FRC #2587
I work for a division of a large multi-national corporation that manufactures motor controllers for industrial applications. Our Chief Technology Officer would like to speak with the team members who developed this, especially those individuals who coded the Victors. He is anxious to know when he can see a demonstration. I am pretty sure that he would be happy to provide sponsorship for your team after seeing your demonstration. Also, please send me your resumes so I can forward them to our CTO. He is always looking for outstanding engineering talent to give us an advantage over our competitors.
Unread 16-01-2016, 23:07
FRC #6069
Rookie Year: 2016
[quote=PatrickSJ; carbon fiber reinforced balsa.
[/QUOTE]
http://dragonplate.com/ecart/categories.asp?cID=58 we had to make the dt light to hover
Unread 16-01-2016, 23:47
FRC #6069
Rookie Year: 2016
thanks for the opportunity can you message me the email at bill1234@gmail.com, so I can send the information. I'm really excited about the evolution of motor controllers. It saddened me that the victor888s were discontinued, hopefully the talons will pick up on their fan design for superior overclocking on the motor controllers.
Unread 16-01-2016, 23:52
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
Have you taken into account the weight of your bumpers? (And possible the aerodynamics as well)
Sleep? What is that? A rare Pokemon?
Unread 17-01-2016, 00:05
FRC #2587
I think our CTO will be out in California the week before the Orange County Regional to visit some partner companies in the renewable energy field. He might be able to extend his trip and attend to see your robot in action. He can then speak with you about how you can scale your technology up into the power range that our products operate in (100 to 1200 hp).
Unread 17-01-2016, 00:10
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Question, Don't really know the answer, but is creating a hover craft actually legal according to the rules. Like has anyone read through the manual to try and find a way where it is not legal.
Unread 17-01-2016, 00:24
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
So long as the bumpers remain within the required zone, there really isn't anything stopping you besides maybe power/weight for the allowed motors. HIGHLY do not recommend this though. No significant pushing power and you will use a tremendous amount of battery power simply moving air.
Unread 17-01-2016, 12:19
Master of Tactics
AKA: Scott Hasek
FRC #1987
Alright thanks.
Unread 17-01-2016, 13:20
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Carbon fiber balsa....
Oh god I'm going to have fun with incorporating that into viable vs practical.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 17-01-2016, 14:23
FRC #6069
Rookie Year: 2016
According to our calculations, the bumpers will lower the height of the hover from 2 in to 1.7496 in, but we have allowed room in the inside of the bottom of our drivetrain to mount more vector 888s to counteract the downward force of the bumpers, we will have to fine tune that a little once the final weight of our robot has been set.
