Re: Java SerialPort kUsb
I've been too frustrated over the past two days to get out of the tunnel vision. As far as the "few seconds" with the bump, I suppose I'm just stupid. I DID look for a rule before I did anything.... |
The built in libraries are most likely the best you are going to get because they interact directly with the FPGA. It may be difficult to get a library that can interact with the RIO's custom RSA ports correctly. You could always do the silly thing and spawn a new thread for every command you wish to send. I'm not too familiar with the libraries provided but if there is some way to terminate the request than you simply send the command, wait 0.3 seconds, terminate the request (eating the error), than send another. (This is under the assumption that the arduino is having no problem processing and returning the data. This is also a very last case scenario! Playing with the FPGA like this is not a great idea). Also, if you want further support, than I'd highly recommend posting code that can be troubleshooted. Theoretical guessing about your issue is to no avail for those who have not overcome the same issue that you are facing. E/ SerialPort does indeed have a reset() command. I'm not sure of the volatility or damage of the command, though. Last edited by Arhowk : 17-01-2016 at 13:26. |
Well, a code snippet is easy (which is why i didn't post one in the first place)
There isn't any ack for this communication... Unless there's something special I have to do with VISA? (I'll look into that) This is our test robot code, literally all of it ( removed some comments to not ake this post huge ) Code:
package org.usfirst.frc.team871.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.SerialPort.Port;
* Default comment
public class Robot extends IterativeRobot {
SerialPort thePort;
Joystick joy;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
thePort = new SerialPort(9600,Port.kUSB);
joy = new Joystick(0);
* This function is called periodically during operator control
public void teleopPeriodic() {
if(joy.getRawButton(1)) {
//System.out.println("Red");
thePort.writeString("!255R000G000B"); //Sends successfully, (Neopixels turn red) then crashes robot code
thePort.readString();
if(joy.getRawButton(2)) {
//System.out.println("Green");
thePort.writeString("!000R255G000B"); //Sends successfully, (Neopixels turn Green) then crashes robot code
if(joy.getRawButton(3)) {
//System.out.println("Blue");
thePort.writeString("!000R000G255B"); //Sends successfully, (Neopixels turn Blue) then crashes robot code
* Default Comment
public void autonomousInit() { }
* This function is called periodically during autonomous
public void autonomousPeriodic() { }
* This function is called periodically during test mode
public void testPeriodic() { }
Most standard communcation will return a checksum with a data good/data bad signal after transmission (as I said, I haven't used the serial port, but it is the easiest way to ensure data integrity, especially since RS232 is bidirectional)
Also, you should always post code when you have an issue regardless of how trivial or complex your issue is. There are some options you should try, in order of when you should do them
Serial communication is about as barebones as you can get, there's no checksum or anything like that. Our little color protocol was intended to be _very_ simple. I (the mentor) never touch code, it's all my students, so I attempt to keep the tasks as simple as possible and build nicer features as their skills grow.
As for the constructor, According to the javadoc Quote:
We tried everything else you've listed (with the exception of changing the default flush mode) before I made my first update to the original post, including different roborios and different ardionos. I hesitate to complicate things with additional threads though. It's not like we're having trouble sending the _second_ command, the robot code simply crashes after the first write. |
I think something probably broke in the USB serial. I saw a few people talking about issues with the NavX in both LabVIEW and Java with USB serial, in code that worked in 2015. If you have an easy way to duplicate it, you should file a bug report.
#7
That's a good idea actually; I'll go do that, as soon as I can find the bug reporting page;
Edit: Ok so Check this out; I signed up for collabnet, then decided to go ahead and pull the entire wpilib source tree. I started poking around tracing the SerialPort calls through their JNI wrappers and into the underlying C++ VISA calls, and found this: The error I posted above maps to the VISA error, VI_ERROR_TMO (in visa.h) Code:
#define VI_ERROR_TMO (_VI_ERROR+0x3FFF0015L) /* BFFF0015, -1073807339 */ Quote:
I wonder if maybe the disableTermination method isn't working properly for some reason. I'm still going to write up a bug, but I think I'll also go create a branch of this source and start doing a little bit of creative debugging myself with a spare roboRio during the week. I'll update this post if I find anything (or the bug gets acknowledged and fixed) WPILIB says that termination is only implemented for receive, but the github bug i linked mentioned that the WRITE might still be expecting a \n or \r. I'll investigate that too. Last edited by AndyB871 : 17-01-2016 at 17:12. |
#8
I ran into something similar last year trying to pair an Arduinio up to our RoboRIO to use inexpensive sensors meant for Arduino. I never did figure it out but only spent an hour on it.
Reading this thread jogged some stuff loose. VISA is a serial protocol standard of sorts that I've dealt with a few times writing software for credit/debit card PIN pads. It's kind of a shot in the dark but have the Arduino shoot back an ACK byte (0x06) after it receives its command. That might make the NI code on the RoboRIO happy. Given that I'm not the only one confounded by the WPILib serial implementation I suspect they're adding VISA rules in there but not documenting them well. It'd be nice if we had something like rxtx available but that does not appear to be easy. |
#9
Thanks again! |
#10
So sending an 0x6, \n or \r didn't change anything. The usbserial still seems to crash the robot code one way or the other. I guess the next step is to track down a plain-ol-jane USB-Serial adapter and remove the arduino from the loop, just in case. I'll update again with more details.
On a secondary note, the MXP UART works just fine (which I suppose isn't surprising). After a little BrainDead(tm) moment we realized that RS232 is NOT compatible with Arduino UART (WHOOPS) which explains why that didn't work. I'm moderately surprised that we didn't murder the Arduino. I guess we were getting a little desperate & careless. Edit: Google managed to find this http://www.chiefdelphi.com/forums/sh...d.php?t=136261 Which the forum search did not, somehow. The post claims that the roboRio is documented to not be compatible with arduino, but I was unable to find said documentation. It also said the MXP port and DIO lines are 3.3v only, which scared me to death at first, but re-reading the RoboRio Manual All DIOs are 5V input compatible, so that's fine. I'm in the process of submitting a bug report to WPI. I feel like this thread should be stickied or something, I've seen a _lot_ of people asking about serial ports and ardunios and such. It would probably be good so that people don't have to repeatedly go though the pain we have to understand the issues here. Last edited by AndyB871 : 19-01-2016 at 23:49. |
