Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Unread 17-01-2016, 11:30
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
What happened to the online JavaDoc??
Last year I bookmarked this page, which had all the documentation for all the WPIlib classes:
http://first.wpi.edu/FRC/roborio/rel...annotated.html
However, when I visit the page this year, I get a 404. Is there even online documentation this year? Where did it go?
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 17-01-2016, 11:52
Re: What happened to the online JavaDoc??
I don't know what annotated.html used to be but whatever it was is the part that's gone: http://first.wpi.edu/FRC/roborio/release/docs/java/
Unread 17-01-2016, 13:14
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Last docs were done with doxygen, I believe. This year we published standard Javadoc, so there is no annotated.html.
Unread 18-01-2016, 20:28
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
If you have the WPILib installed and 'built' on your "laptop", there is a local version of the javadoc in C:\Users\{username}\wpilib\java\current\javadoc (more or less) ... not sure if that satisfies your requirement for the info, as it is local and not online.
Unread 21-01-2016, 19:32
minutebot minutebot is offline
Programming Captain
FRC #4536 (The Minutebots)
minutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of light
I believe this is what you are looking for!
