Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
  #61   Spotlight this post!
Unread 15-01-2016, 16:32
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: We are going to Want a GRIP fourm
Originally Posted by H2O Enthusiast View Post
By robotMain() do you mean outside the robotInit() but inside the Robot() class? Also, by operational part of my code do you mean where I publish the data?
Yes to both questions. If you look at SampleRobot.java (the base class your code is using), you'll see there's a number of different functions you can override. robotInit() is one. robotMain() is another (as is operatorControl(), disabled(), autonomous(), etc). The startCompetition() function shows the sequence in which these functions are called. robotInit() is called first, and should contain only initialization code -- code you want to run before the match. Only after robotInit() returns does startCompetition() call the FRCNetworkCommunicationsLibrary to let the driver station know robot code is ready to run (which is what makes "No Robot Code" disappear). Note it's somewhat risky to override robotMain() instead of the individual operatorControl(), disabled(), etc. functions, as you will need to handle the state transitions between these modes yourself (versus having startCompetition() handle it for you).
While SampleRobot is okay for small test programs like this one, for your actual competition robot code, if you don't want to do command-based programming, I recommend you use a different template such as IterativeRobot and override only robotInit and the various autonomous/operatorControl functions. The IterativeRobot class startCompetition() function will take care of calling these functions in the right order and putting in appropriate delays to not swamp the CPU.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
  #62   Spotlight this post!
Unread 15-01-2016, 18:57
hewittalec hewittalec is offline
FRC #0058
hewittalec is an unknown quantity at this point
Hello. New to vision processing.
I'm trying to deploy GRIP to my roborio but no luck. It doesn't tell me that it failed, it simply spins and there is no run button or console activity. I've tried deploying to roborio-58-frc.local and other ip addresses.
As a side note I also cannot get Network table data from the outline viewer. thanks.
  #63   Spotlight this post!
Unread 15-01-2016, 21:59
1337WaffleBendr 1337WaffleBendr is offline
FRC #5489
1337WaffleBendr is an unknown quantity at this point
Same :-/
  #64   Spotlight this post!
Unread 15-01-2016, 22:35
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
I honestly can't help much with deploying, maybe try checking the issues page for similar problems.
If you go to the chat you can also talk to @JLLeitschuh, who wrote the deploy code.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
  #65   Spotlight this post!
Unread 16-01-2016, 12:36
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
When the robot is on Communication to the drivers station with the smartdashboard working and displaying data from robot code run GRIP on the PC. Set the GRIP project NetworkTable address to 10.TE.AM.20 (Is you TEAM 0058?) if not your roborio-58-frc.local is wrong and should be roborio-TEAM-frc.local were TEAM = your number 1234. Now create a pipeline in GRIP to write data to the Network table. Online Viewer.jar should show your smart dashboard data and Grip Data. You must also enter 10.TE.AM.20 in the Online Viewer and select client. Or Test GRIP not using the Roborio by tring to follow a suggestion I made on the GRIP issues pages. https://github.com/WPIRoboticsProjects/GRIP/issues/349
  #66   Spotlight this post!
Unread 16-01-2016, 23:44
Rookie Year: 2015
new page to the wiki
Tutorial:-Deploy-to-the-Robot
  #67   Spotlight this post!
Unread 17-01-2016, 12:48
team-4480's Avatar
team-4480 team-4480 is online now
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
This may sound really stupid, but for the life of me, I can't figure out how to get the results from the "Publish ContoursReport". I don't want to deploy it onto the robot yet, but I want to be able to see what the X and Y coordinates it finds in the sample images so I can try and write a program that would make decisions on it.
  #68   Spotlight this post!
Unread 17-01-2016, 12:55
Rookie Year: 2015
I did share a way with the developers and they marked it as a Wiki item. I just started poking through their code and with their blessing my help and write this to the Wiki. For the mean time check this out.
  #69   Spotlight this post!
Unread 17-01-2016, 13:11
team-4480's Avatar
Debug? What's that?
FRC #4480
Is there a way to just get the Outline Viewer? We use Python so I would rather not have to install Eclipse and Java in order to just use the one program.
  #70   Spotlight this post!
Unread 17-01-2016, 13:25
Rookie Year: 2015
I wonder if you could extract it from the off line Java tools install method mentioned at the end of the "Installing Eclipse (C++/Java)" set up pages.
  #71   Spotlight this post!
Unread 17-01-2016, 14:32
MultipleMono's Avatar
MultipleMono MultipleMono is offline
Programmer & IT Guy
FRC #3128 (Aluminum Narwhals)
MultipleMono is an unknown quantity at this point
To everyone having deployment problems, you can also try to deploy it manually:
1. Set your publish address in GRIP's settings to your RoboRIO's address (roborio-<teamnumber>.local)
2. SCP (using PuTTY pscp on Windows) app/core-1.0.0-all.jar from GRIP's install location (typically C:\Users\<username>\AppData\Local\GRIP) to your RoboRIO:
pscp app\core-1.0.0-all.jar lvuser@roborio-<teamnumber>.local:/home/lvuser/GRIP.jar
3. SCP your grip profile:
pscp profile.grip lvuser@roborio-<teamnumber>.local:/home/lvuser
4. Login over ssh/PuTTY to the lvuser account
5. Start GRIP:
java -jar GRIP.jar profile.grip
  #72   Spotlight this post!
Unread 22-01-2016, 12:22
FRC #0237
Originally Posted by ajaquin3171 View Post
Has anyone been able to successfully deploy grip to their roboRio? Every time we try to deploy it we get a message saying that it failed. Has anyone encountered this error before? The firewall on our laptop is also turned completely off as well.
Originally Posted by Mark_Ebert View Post
We have tried using the advanced tab and retyping in the roboRio's address and have tried it using the mDNS and the IP address wirelessly and also directly connected to the roboRio through the USB 2.0 type B cable and none of these way seems to be able to deploy to the roboRio from GRIP. Though running GRIP from our pc we are still able to have it work and successfully use the Network tables, we are just unable to have the program deploy to the roboRio so that we don't require the laptop.
FYI GRIP v1.1.x is out now. This show hopefully fix all of your deploying problems and more.
