Go to Post "But from a real life standpoint, that looks like something the evil villains in a superhero movie would use to get around in" Reading the phrases "real life" and "evil villains in a superhero movie" in the same sentence makes me giggle. - Alan Anderson [more]
Unread 17-01-2016, 13:01
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
West Coast Drive is Illegal?
According to R2:
"The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is
comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater
than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME
PERIMETER."
I would interpret wheels as articulated elements, therefore WCD designs are illegal this year. Or am I missing something?
Unread 17-01-2016, 13:12
piersklein piersklein is offline
piersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the rough
Re: West Coast Drive is Illegal?
Please read the blue box of the rule:
To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the BUMPER ZONE described in R22. The string describes this polygon.
The frame perimeter is composed by non articulating structural elements but is defined by wrapping a string around the robot at the bumper zone. As such, a west coast drive that is under the max frame perimeter while determined by this method would be legal.
2016 Boston Semifinalists
2016 UMass Dartmouth Creativity Award, Quarterfinalist
2015 Northeastern Quarter Finalists (6th rank)
2015 UMass Dartmouth Winners
2014 RISM Rookie Inspiration Award, Semifinalists.
2014 NorthEastern Rookie All-star, Highest Rookie Seed, Semifinalists.
2014 NECMP- Highest Rookie Seed
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Articulation implies a flexible joint. West coat drive wheels are on a fixed frame and do not move with respect to the frame.
In any case, the restriction is regarding the frame, and not parts.
Unread 17-01-2016, 13:13
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Bumper rules are much like 2014. West coast drives then as now need structure outside the wheels to define the frame perimeter and support the bumpers. The west coast drive "frame" is well inside the frame perimeter for a legal robot
Unread 17-01-2016, 13:21
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
All this said though you can still make an illegal west coast drive
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 17-01-2016, 14:05
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
You can. You can also make a legal one.
The relevant requirement is R26.
R26 BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-9). To be
considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the
FRAME PERMIETER. Additionally, any gap between the backing material and the frame:
A. must not be greater than ¼” deep, or
B. not more than 8 in. wide
A west coast drive with protrusions at the corners that stick out past the wheels will provide a nonarticulated structural element. So long as bumpers are supported in accordance with the rules (likely requiring multiple protrusions no more than 8" apart) then it will be legal. Note that R21G is also relevant to this situation:
G. must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form
a tight, robust connection to the main structure/frame (e.g. not attached with hook-and-loop,
tape, or tie-wraps). The attachment system must be designed to withstand vigorous game
play. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of
the BUMPERS.
A robot inspector will be looking for a robust support structure that meets the requirements and is capable of withstanding the impacts of the game environment. So long as I can run a string at the bumper zone (between 4in and 12 in above the floor) and only touch nonarticulated structural elements then it should be legal.
Unread 17-01-2016, 14:17
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Here are two examples of frame perimeters of a west coast style frame. The not legal one has a wheel defining the frame perimeter. The wheel moves relative to the frame so is not legal. To be legal the bumper would have to be attached to and be supported by the wheel. Not useful. On the legal frame, the upper frame defines the frame perimeter because it is in the bumper zone. If was not there the robot would still be legal because the front rail would define the frame perimeter, not the wheel. Bumper support rules would still have to be met.
While probably not as heavy defense year as beach ball bot, Good practice says you want to keep the bumpers from being driven into the wheels.
Name:	not legal perimeter.jpg
ID:	19766  Click image for larger version
Name:	legal perimeter.jpg
Unread 25-01-2016, 13:51
pribusin's Avatar
pribusin pribusin is online now
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
What if you are using 8" wheels? You can no longer satisfy R26 which states that you must have perimeter frame support for bumpers with gaps not exceeding 8 inches. do you have to have an outer frame member that covers the wheels from end-to-end?
Unread 25-01-2016, 14:02
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can have 11-1/4" wheels and still have a 3/4" wide continuous frame support/member fully supporting the bumpers with no gaps....
Unread 25-01-2016, 14:11
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
You could do what 118 did in 2014. Take a look at post #27 on this thread.
http://www.chiefdelphi.com/forums/sh...postid=1515197
- Everett
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 25-01-2016, 14:25
pribusin's Avatar
Uber Alien
AKA: Mike 1
Hmmmm... not the kind of engineering I want to teach my team. I get how one can circumvent rules to remain 'legal' however that doesn't necessarily make it sound engineering. I was hoping for both a legal way AND a way that follows the spirit of the rule which, I believe, is for the frame perimeter to support the plywood bumper base sufficiently so that it doesn't crack during collisions.
Unread 25-01-2016, 14:31
Billfred's Avatar
Billfred Billfred is offline
If your frame meets the specifications of the end customer, there's no circumvention. Whether that's enough for your bumpers to have a safe home is a separate topic, but WCD with bumpers is a solved problem (generally, by adding a bar across the sides in some compliant manner to define the frame perimeter and provide the bumpers a good home).
Unread 25-01-2016, 14:55
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
What data do you have that it will necessarily crack during collisions? That it isnt sound engineering?
We have built them similarly to 118 in the past, drive the heck out of our robot, collisions and all, with no cracks in our plywood bumpers ever.
I'd say it was pretty sound.
To each its own.
Unread 25-01-2016, 15:32
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Also, the rule (R21) says, "plywood or solid, robust wood". If you're worried about breaking the wood backing you could use something like, oh say, solid ash. The "structural element" supporting the bumpers doesn't need to be nearly as robust if you manifest that strength and stiffness in the bumpers. Many teams actually rely on the bumpers to enhance the strength of their overall robot, because there is effectively free weight to be had in the bumpers which could be and has been played off as "attachment features"
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 25-01-2016, 15:36
Andy A. Andy A. is offline
Getting old
FRC #0095
It does make me wonder how many teams will pursue a 'west coast drive' this year. I know cantilevered wheels and the rougher defenses make me nervous, but I've never been terribly bold.
So, who's going for it?
