Robotbuilder c++ code dies in Test Mode
Finally got example robot programs to run after Plugin update. Thanx.
Now I tried the most simple RobotBuilder C++ code (one subsystem with one speed controller). exported, imported, built and deployed OK. When I select Test Mode then enable. The Drivers Station indicates Test Enabled for 1/2 second, then Test Disabled. The roborio Mode indicator goes Red, then Comm indicator Red, then Mode goes off and Comm goes back to green. |
