Go to Post This looks like a job for duct tape! - JoeXIII'007 [more]
Unread 17-01-2016, 16:02
Pyro_84 Pyro_84 is offline
FRC #1769
Pyro_84 is an unknown quantity at this point
Build Works/ Deploy doesn't
I can build the Labview program I've written to our roboRIO, bur when I attempt to deploy the code it states "the network address might be invalid or the target is not responding" I don't know how to fix this though.
Any suggestions?
Unread 17-01-2016, 17:29
Re: Build Works/ Deploy doesn't
Have you tried using the USB cable?
Has the roboRIO has been setup for 2016 (firmware 3.0.0f0.cfg & image 2016_v19)?
Can you browse to the roboRIO using IE or the modern equivalent?
On the project explorer window check that it has the correct address for your team:
Target (roboRIO-1769-FRC.local)
