#31
Re: pic: Shooter damaged a Boulder
Has FIRST been able to offer a good reason WHY basic foam balls are priced so highly?
#32
Not so basic. They had a lot of criteria to hold. |
#33
Some new testing with our wheeled shooter for the GreenHorns showed some great results. We started playing basketball with one of our boulders around 3 AM (used the tower for our hoop... hopefully robots will be more accurate than me...)while waiting for the programmers and it got pretty beat up. When they were finally finished we set our robot up in an orientation that it was making 100% of its shots with that beat up ball. Next we introduced an untouched ball to the shooter and it was still successful.
The tests tell me that wheeled shooters aren't terribly affected by wear on the boulder. For reference we were shooting from about 7-10 feet away from the tower. |
#35
We have already tried both a wheeled shooter and catapult prototype design with the option to change certain variables.
Compression on a wheeled shooter seemed optimal at 3" compression. We tested 2" also with poor results. We also used direct drive CIMs on an older AM wheel similar in texture to the stealth wheel. We didnt even bother trying the plaction wheels because our goal isnt to create a shredder. ![]() Shooters and catapults have already been built by many teams and there are a ton of old video clips from previous seasons. IMO, building either is the trivial part. Last edited by waialua359 : 13-01-2016 at 03:53. |
#36
I will testify that the catapult works, I will also testify that it creates one hell of an accuracy problem.
#38
https://www.instagram.com/p/BAdNlxTj...y=team293spike |
#40
In addition, keep close mind of how you are powering the catapult. If you are using motors, it will be inaccurate unless you are accounting for battery voltages, motor speeds, etc. If you are using some type of spring, get a fish scale so you can measure the spring tension and make sure it is consistent. Also insure you are shooting from a hard stop to another hard stop on the motion so that the catapult follows a proscribed motion each time. People with wheels need to worry about slip, moment of inertia, and wheel velocity and how the ball is introduced to the shooter. Catapults just offer different challenges. |
#41
We just received two Rhinoskin balls.
Both measured the same diameter as our KOP ball +about 1/16th". ![]() In addition to measuring their diameter, we compared their compress-ability to both a new KOP ball and the well used one in the image. We placed a 13.875 LB battery on the ball and measured it's compressed height. Used KOP boulder = 8.25" New RhinoSkin = 8.5" New KOP boulder = 8.675" So, all in all, they appear to be a good match. That said. actually shooting them will be the real test! |
#42
We put a small tear in the skin not by the spinning wheels but by hitting a corner inside the tower. We have since put a stop (piece of lexan) in the tower to stop the boulder and roll it back.
We are using 4" plaction wheels spinning at 2950RPM and have only minor scuffing on the skin. We are compressing the boulder 2" and are able to hit the high goal consistently (19 for 20) sitting on the outer works. |
#43
How are you controlling the 2950RPM? |
#44
We aren't really controlling it. Using a Banebot RS775 with a 3:1 transmission. Running at full power our tach shows a constant 2950 +- 15RPM. No encoders installed. The shooter is a prototype but it shows a lot of promise.
#45
But you say the motor is spinning at only 2950*3 = 8850 rpm with a fully charged battery. 8850 rpm is only 68% of free speed. Of course the motor speed will be less than its free speed, but 68% is quite a bit less. Some rough calculations indicate the motor would be drawing in the neighborhood of 30 amps. Can you measure the amps the motor is drawing to confirm this? Quote:
