Go to Post If the GDC made a game that consisted of driving in a straight line, it would probably be the hardest game in FRC history. - themccannman [more]
Unread 17-01-2016, 11:38
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Change smart dashboard network table to 127.0.0.1
I would like to do some off roboRio code testing with the smart dashboard. Like with the online viewer that can be the host network table at that address can I get the Smart Dashboard to be a client to side address?
Unread 17-01-2016, 13:36
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Change smart dashboard network table to 127.0.0.1
Well, the SmartDashboard uses the java NetworkTables library which communicates via generic TCP, it shouldn't depend on the host at all. Did changing the IP to "127.0.0.1" or just "localhost" not work?
You can run it from the command line with the argument -ip 127.0.0.1 (or localhost). This is also what the eclipse wpilib menut Run Simulation Smartdashboard item does.
Unread 17-01-2016, 16:42
Rookie Year: 2015
I did not find a spot to even enter a IP address in the Smart Dashboard preferences. Only a Team number. I will go look deeper.
Unread 17-01-2016, 17:26
Rookie Year: 2015
Yes run from cmd worked. But you knew that. Thank you
Unread 17-01-2016, 17:43
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Oh, my apologies, most FIRST software allows you to specify an IP whereever it says "Team Number" but I guess SmartDashboard doesn't.
