Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 17-01-2016, 16:28
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Has WPI fixed the timing errors from 2015?
I recall timing errors with java in 2015 made it very hard for teams to use PID loops (the D part, mostly). Does anyone know if these have been fixed? I scanned over the wpilib website and found no information on this.
Unread 17-01-2016, 17:37
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Has WPI fixed the timing errors from 2015?
I don't recall any timing errors other than built in scheduler functions being unable to resolve themselves properly because the RIO doesn't keep time when turned off, and this hasn't changed at all. What timing issues are you referring to? System.currentTimeMillis() works fine iirc
Unread 17-01-2016, 18:01
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I think Ahad is referring to this:
http://www.chiefdelphi.com/forums/sh...1&postcount=20
Unread 17-01-2016, 18:16
The notifier class was added to java, but it doesn't look like the PIDController class was updated to use it.
