Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 17-01-2016, 18:01
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Red face Re: navX 2016 Software Reset Displacement
Originally Posted by Jonathan L. View Post
We are looking at using the navX displacement values for automode.
We are communicating with it via SPI, and receiving yaw, pitch, roll etc. We can reset the yaw. However, I can not find a function to reset the displacement. Is there one?
Do you have any other tips for using displacement? I may have other questions moving forward.
Originally Posted by euhlmann View Post
In C++ there is a ResetDisplacement function, so I'm surprised it's not in labview. I guess you'll have to define your own offset variables and subtract those from the values.
The only other thing I would say is not to rely on it too much. Since it works from the accelerometer it may be inaccurate, especially if your robot shakes around (eg going over the rough terrain, rock wall, etc), and it will get more and more inaccurate over time (like yaw, hence the reset functions for both in C++).
Definitely don't use it as the only metric for your position. Use rangefinders or image processing to confirm it.
My bad, I missed adding those reset commands, oops . Check the Latest Release, I've just added those functions. Thanks for catching that.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
