Go to Post they used the same random number generator we used for our autonomous drive code . . . (oops did I say that?) - MrForbes [more]
Unread 16-01-2016, 14:34
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Error when imaging RoboRIO
I've tried reimaging the RoboRIO, but I constantly get this same error message:
I've tried this on two different computers, and over USB and Ethernet, but I always get this message.
Head Programmer / Driver
Unread 16-01-2016, 14:59
chubchub5577's Avatar
chubchub5577 chubchub5577 is offline
FRC #1802
chubchub5577 is an unknown quantity at this point
Re: Error when imaging RoboRIO
Try having BOTH USB and ethernet plugged into the computer when doing this, I know it sounds weird but that has saved my bacon a few times!
Unread 17-01-2016, 18:19
cjl2625's Avatar
apel py
AKA: Cory Lynch
With this roborio, I also tried updating the firmware. I can't login, as the default username "admin" and blank password doesn't work. Maybe this is related to why the imaging tool also does not work.
Is there a way to reset the login settings, or otherwise format the roborio without requiring login?
Unread 17-01-2016, 18:23
Your best bet is to call NI Support: 866-511-6285 1:00-7:00 PM CST Monday - Friday
Unread 18-01-2016, 02:07
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
I had a similar situation with my imaging tool running Windows 10 and returning that error. I am assuming you are on Windows 10. This could be an mDNS issue. This was my explanation for the network resolution that fixed the both the radio config problem and the error the rio imaging tool was throwing. It was the same error message as yours.
http://www.chiefdelphi.com/forums/sh...d.php?t=141688
I am having lots of problems this year with my laptops connecting with my radios. There are lots of reboots. It might be some sort of ARP table problem or cached IP addresses somewhere. Power off your laptops and rio and start clean.
Unread 18-01-2016, 20:44
cjl2625's Avatar
apel py
AKA: Cory Lynch
I made sure all the sharing settings were good, and it still doesn't work.
Also uninstalled antivirus and turned off all firewalls. Tried booting into safe mode. Nevertheless, it's always the same result.
Unread 18-01-2016, 22:55
Capitalize the first letter of Admin, not lower case.
But I'd also suggest asking the NI Support desk. That's what they're there for.
Unread 18-01-2016, 23:11
FRC #3944
I may have missed it, but is this win10? have you powered down completely? There is another software NI has called NIMax. They may ask you to install NIMax as an alternate means of installing to the rio. One last question can u see the MAC address of the rio in the installer?
Call NI Technical Support
NI Technical Support is here for those tricky questions and hard-to-troubleshoot issues. Call us Monday through Friday, from 1 p.m. to 7 p.m. CST. You can also email us through the link below.
866-511-6285
Unread 19-01-2016, 20:39
cjl2625's Avatar
apel py
AKA: Cory Lynch
866-511-6285
Yes, it's win10, though I've also tried it on a win7 computer with the same results.
I can see the MAC address of the rio, and I can communicate with it normally from the driver station.
Pretty sure the issue is just that the login username/password was somehow changed, and it needs to be reset.
I suppose I'll give NI support a call tomorrow night.
Unread 19-01-2016, 21:42
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Are you upgrading the firmware or the image?
There are two upgrades that have to happen. I think you need to do the firmware first. Instructions are here: http://wpilib.screenstepslive.com/s/...borio-firmware
Firmware is via the web interface. The image file is via the NI tool. I would guess that trying to put the latest image on there without the latest firmware could cause issues.
Unread 19-01-2016, 22:39
cjl2625's Avatar
apel py
AKA: Cory Lynch
I've tried doing both, and neither have worked
Unread 19-01-2016, 22:53
If you can't login to the roboRIO as Admin through the browser interface, then things aren't going to work.
Other apps depend on that to get admin privileges on the roboRIO.
Unread 22-01-2016, 14:58
Mentor!
AKA: Eric Pylko
Rookie Year: 1970
Did you get your RoboRIO upgraded?
Unread 22-01-2016, 19:33
cjl2625's Avatar
apel py
AKA: Cory Lynch
Yes, we got it working.
We called NI technical support and obtained a file to wipe the RoboRIO and start fresh.
Doing that reset the password to the default, so I was able to log in and install firmware/image the rio.
Unread 23-01-2016, 21:42
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
866-511-6285
We had similar problems, and were ready to punt until we could call NI on Monday. Then I remembered NIMax. Fell back to it today and successfully got the brain surgery done.
NIMax apparently is not in the LabView tools installation, but is in the LabView distribution. Had me thoroughly confused why it was on my personal machine, but not on the team laptops. Then remembered I was resisting the Java Borg and installed LabView on my machine as a backup.
Tim
Software Mentor
3853 Pridetronics[
