Go to Post This is real. This is hard. This, is FIRST. - sanddrag [more]
Unread 17-01-2016, 19:16
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: 8" Pnumatic Wheels @ Andymark soldout
Originally Posted by BBray_T1296 View Post
I took the CAD of the hub off of Andymark and modified it to be a bit more 3D printer friendly.
If anyone is feeling brave enough to try running a printed hub, I posted it to Thingiverse.
It should fit any 200x50mm tire and inner tube which can be found all over the place.
Be sure that the outer diameter is thick enough, I had trouble with it not having the thickness to get three full layers in so I ended up with two layers and a hollow gap between them.
Did you remove all of the fillets? Doing that cut supports in half after I took the draft off and made my own spokes so it would be prettier.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
