Re: Is Bowling thought the Low Bar legal
I boils down to .....
"The OUTER WORKS impede the passage of ROBOTS and BOULDERS into the COURTYARD. ROBOTS move BOULDERS across the OUTER WORKS into the COURTYARD one-at-a-time. " "The OUTER WORKS.... is designed to impeded the passage of ROBOTS and BOULDERS in to the COURTYARDS" There are RULES (G40) for Robots and NONE for Human Players. So in Theory IF a Human Player can get the boulder from one of the two holes in the EMBRASURE and into the opponent courtyard you just beat the design to impede that and NO FOUL. And good luck with that. We want you on our alliance. Last edited by Boltman : 17-01-2016 at 21:45. |
To be a little less cryptic. Update 2 added rule G40-1 prohibiting a robot holding/propping the low bar flap open and the drive team rolling ball through it. So while not specifically prohibited, bowling a ball through the low flap would be difficult.
If you really wanted to game the system, one thing you could do is have your ROBOT grab the cloth and instead of holding it open, simply hold it taut at an angle such that when the Human Player punts the ball through the embrasure, the cloth of the Low Bar behaves like a ramp, propelling the ball over.
Although it then causes some ambiguity over the definition of "open" and "closed": "not closed or barred at the time, as a doorway by a door, a window by a sash, or a gateway by a gate: " - Dictionary.com |
Q528 caused it to be illegal, creating G40-1 in update 2.
Last edited by timtim17 : 17-01-2016 at 22:14. Reason: moved a space out of a link |
#7
Instead of the robot holding the cloth, how about the robot in the shape of a wedge, and the boulder "hits" the robot and "bounces" over the low bar?
#9
Even if you figure out a way to do it, this robot would be violating G40. Quote:
#10
Also, G40-1 was added to clarify the intent, that only ROBOTS can move BOULDERS, one at a time, into the COURTYARD. This also came up in the Q&A. |
#12
If a human player where to enter the ball in fast enough and get it over the ramp parts in slot 2 (next to the low bar) is it legal?
#13
As the rules currently stand? Yes. Is it against the intent of the rules? Yes. Also, I would play around with the physics of the field, but I don't actually think it's possible to get an angle on the Ramparts from the Embrasure from the HP station.
#14
However, there is no guarantee that the RAMPARTS are going to end up next to the LOW BAR, and realistically if any team thinks anyone can bowl through there they are going to select a different DEFENSE that is harder to bowl over. Remember, per section 5.5.10, the opposing ALLIANCE chooses the DEFENSES in slots 2,4,and 5 and they have control which choice goes where. |
#15
Legal currently however at any time they could pull the "intent of game" clause like they did for holding low bar carpet up by bot. I would not count on that strategy.
