Go to Post Invest our time in enhancing the process of conceiving, designing, testing and deploying the game - billylo [more]
Unread 18-01-2002, 20:10
Tyler Olds Tyler Olds is online now
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Question RAM Requirements
Hey everybody,
I was just wondering if there is a recomended amout of RAM you should be using on your comps for 3ds max. Right now i have 512 on mine but I am still lagging when I load my animation and try to alter it. So i was just wondering if there were ways to reduce lag, or do I just need more ram.
Thanks
Tyler Olds
Head Animator
Team 93
Tman_86@yahoo.com (there's an _ )
AIM S/N Soccerreffreak
Unread 18-01-2002, 20:15
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Smile Graphics
Let me start off by saying i'm no 3d Studio Max expert.....but i'm almost certain that if you got a better graphics card that should smooth some things out big time....
Purdue Alumni
Cummins, Inc.
Unread 18-01-2002, 20:58
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
RAM is mostly used to hold bitmaps that are being applied in the image. The more you use 'em, the more RAM you need. Most of the rest is processor lag, not a RAM issue.
Unread 18-01-2002, 21:30
Robby O's Avatar
Robby O Robby O is offline
no team (Volunteer)
Robby O is an unknown quantity at this point
Send a message via AIM to Robby O
Ram Ram, the wonderful chip...
The more you have the less performance dip...
The less performance dip, the faster you create
So add more rame and dont procrastinate!
Ah, yes, more ram CAN mean better loading. But usually it's just better with large scenes AFTER they're loaded - No time writing to the page file on your hard drives - which can also be improved with SCSI as opposed to IDE drives.
Also, how large are your scenes (megs)? How many poly's? Are you using any XRef's? Are you displaying everything or only what's neccisary to animate? Are you also displaying textures? Do you have degradation on? Are you using optimize on high in the viewport and no optimization for rendering? All this can contribute to lag when changing a scene.
And if you do decide to pick up a graphics accelerator, check various graphic magazines and websites and the packaging or specs of the card. Most game accelerators DO NOT actually work to help out the rendering process in MAX unless they are specifically stated as doing so. So make sure you know what you are getting, and ask around before making a purchase. Also try http://www.journeyed.com for good deals on good cards. I'll see what I can find on the web and I'll let you know.
Good luck at card hunting, and happy rendering!
-Robby O
FIRSTanimators Moderator
oshortwan@hotmail.com
-Robby O
"If I had it in me
To stop these random thoughts
And non-stop dreams
I could deal with this
Non-stop spinning world" -Less Than Jake
Unread 19-01-2002, 00:37
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
512 megs of ram is plenty. I used to have 512 megs (I have a gig now) and I could run 3dsmax along with several other programs such as photoshop and internet explorer without seeing performance hits. I watched the task manager once when I was doing some heavy stuff in 3dsmax (such as rendering with raytracing) and it never went higher than 220 megs.
How fast is your processor? That probably has something to do with it.
Unread 19-01-2002, 14:24
FUN Show Host
ram
the procesor on this comp is 1 ghz. So i would think that would be pleanty.
Tyler Olds
Head animator
Unread 19-01-2002, 14:31
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
not positive if 3ds supports hardware t&l, but if it does than you would be best off getting a good nVidia graphics card, >=geForce 2
Unread 19-01-2002, 14:47
FRC Key Volunteer Trainer
AKA: CrazyNate
As Robby mentioned, your run-of-the-mill 3d accelerator will not help out with 3DS Max. Most 3d accelerator cards are designed to go from video memory(where things go after the 3d chip does it's work) directly to the monitor. Depending on driver support, it may or may not help with your previews(don't remember which of OpenGL/Direct3D/etc. 3ds max supports), and it most likely will not help your final render, unless the driver supports copying the result data from the video memory back to main memory for copying to the hard drive.
Nate Smith
nsmith@smythsoft.com
Unread 19-01-2002, 15:05
Spike2756 Spike2756 is offline
#0824 (SWAT Robotics)
Spike2756 is an unknown quantity at this point
Send a message via AIM to Spike2756
Man, 512 is plenty of RAM. This summer I was a production software engineer at a game company and I ran 3Dmax 4.2 on my issued p3 550 with 256mb of ram and a old GeForce256. I actually tested a system there with a p4 1.4ghz, 512mb ram, and a GeForce3 (non Ti) and it actually only ran max a little faster then my slow hunk of junk. In the end I think it just comes down to the size of the sceneyou are working with
University of Washington Junior
Lead - Animation
Member - Wiring and Controls
AthlonXP 1800+
ECS K7S5A w/ SiS 735
512MB Crucial PC-2100
Radeon 8500
And a whole ton of games ;-)
Unread 21-01-2002, 11:58
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
Im running 3DS max on my 400 mHz celeron with 64 megs ram and it runs... i think i might want to invest in some more ram/faster processor/whole new system
Where has all the fun gone?
Unread 22-01-2002, 18:48
Ghetto_Child's Avatar
Ghetto_Child Ghetto_Child is offline
#0253 (Mills Robotics Team)
Ghetto_Child is an unknown quantity at this point
ram
ram shouldnt help too much
try some other upgrades, try this link
www.pricewatch.com
What are your team's requirements? SaxMan701 Team Organization 28 26-09-2003 18:00
Scratchpad RAM Access Time Ian W. Programming 1 13-02-2003 00:31
Adding RAM to RC archiver 2001 1 24-06-2002 00:59
Out of RAM Space on Custom Program archiver 2000 4 23-06-2002 23:07
BS-2sx RAM access times archiver 2000 2 23-06-2002 22:10
