Go to Post The size of your team has nothing to do with the size of your heart. - Amanda Morrison [more]
Unread 17-01-2016, 22:26
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
NavX MXP Accuracy
Before we buy a NavX MXP, we'd like to know the following:
Is it reasonable for us to expect that using the NavX to determine the robot's position relative to the field will remain reasonably accurate for a two and a half minute FRC round?
Unread 17-01-2016, 23:27
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: NavX MXP Accuracy
When you say reletive to the field, are you referring to heading, your xy coordinates, or both? If it is just your heading I would think you'd be ok, however if you're trying to us the navX to track your xy coordinates aswell, you will most likely deal with a substantial amount of drift.
Disclaimer: I have never used the navX board, this response is purely based on what I have read others post here on chief.
Unread 17-01-2016, 23:40
electronicsdude's Avatar
electronicsdude electronicsdude is offline
AKA: Spencer
FRC #4918 (The Roboctopi)
electronicsdude will become famous soon enoughelectronicsdude will become famous soon enough
We used one positioned on to of your robot relatively centered to run our mechanum wheels in a field oriented drive. Just set up to recalibrate when the match starts we never had any issues with the rotation drifting. In my opinion plenty accurate for a 2-minute match.
Unread 18-01-2016, 00:06
slibert slibert is online now
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
If you are referring to orientation (rotation of robot with respect to the field), absolutely yes. Hundreds of teams have used NavX-MXP for this.
Unread 18-01-2016, 11:22
What about orientation and x,y co-ordinates?
EDIT: Never mind, I think I found my answer:
"Accelerometer data from the navX-MXP’s onboard MPU-9250 are double-integrated by the navX-MXP firmware to estimate displacement, and are accurate to approximately 1 meter of error during a 15 second period."
http://www.pdocs.kauailabs.com/navx-...ked-questions/
So it's a definite no.
Unread 18-01-2016, 15:47
Software Mentor
AKA: Scott Libert
There's much discussion on chief Delphi on how to address this. It's pretty well known that there is currently no single sensor that can track position to the required accuracy for FRC. Teams are having success by a solution that fuses multiple sensors:
- wheel encoders + navX-MXP
- vision processing w/camera w/navX-MXP
- a combination of all of the above
- using a "follower wheel" that has a wheel speed encoder (for distance traveled) and an angle encoder (for current direction of travel).
Unread 18-01-2016, 20:21
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
If you want absolute position over the whole duration of a match, I don't think encoder wheels will cut it this year, with all the bumps and various defenses, not without re-zero-ing repeatedly.
But why?
