Go to Post FIRST is different... we commute, journey, and make pilgramage to attend our events. Something that is expensive and exclusive. - Erin Rapacki [more]
Unread 17-01-2016, 23:29
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
nandeeka is on a distinguished road
GRIP Throwing Exception Upon Deployment
We just started exploring GRIP and are have trouble deploying a GRIP program to the roboRIO.
After creating and saving a program in GRIP, when we go to deploy, we get the following exception:
An event subscriber threw an exception
## Stack Trace:
```java
java.lang.IllegalStateException: Tried to stop IP Camera 10.18.68.11 but it is already stopped.
	at edu.wpi.grip.core.sources.CameraSource.stop(CameraSource.java:296)
	at edu.wpi.grip.core.sources.CameraSource.onStopPipeline(CameraSource.java:338)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at com.google.common.eventbus.EventSubscriber.handleEvent(EventSubscriber.java:74)
	at com.google.common.eventbus.SynchronizedEventSubscriber.handleEvent(SynchronizedEventSubscriber.java:47)
	at com.google.common.eventbus.EventBus.dispatch(EventBus.java:322)
	at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:304)
	at com.google.common.eventbus.EventBus.post(EventBus.java:275)
	at edu.wpi.grip.ui.DeployerController.onDeploy(DeployerController.java:107)
	at edu.wpi.grip.ui.deployment.DeploymentOptionsController.lambda$deploy$21(DeploymentOptionsController.java:81)
	at org.jdeferred.impl.AbstractPromise.triggerDone(AbstractPromise.java:107)
	at org.jdeferred.impl.AbstractPromise.triggerDone(AbstractPromise.java:98)
	at org.jdeferred.impl.DeferredObject.resolve(DeferredObject.java:70)
	at edu.wpi.grip.ui.deployment.FRCAdvancedDeploymentOptionsController.lambda$onDeploy$29(FRCAdvancedDeploymentOptionsController.java:78)
	at org.jdeferred.DeferredFutureTask.done(DeferredFutureTask.java:83)
	at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:384)
	at java.util.concurrent.FutureTask.set(FutureTask.java:233)
	at java.util.concurrent.FutureTask.run(FutureTask.java:274)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
## System Info:
Property Name | Property
GRIP Version | 1.0.0
java.version | 1.8.0_66
javafx.version | 8.0.66
os.name | Mac OS X
os.version | 10.11.2
os.arch | x86_64
Thanks for your help.
Unread 18-01-2016, 02:32
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: GRIP Throwing Exception Upon Deployment
This is a bug in GRIP 1.0.0 that was just fixed a few days ago. The next minor release (probably some time this week) will have this fixed.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 18-01-2016, 10:53
nandeeka's Avatar
FRC #1868
Great, thanks for your help!
Unread 20-01-2016, 16:53
dcarns dcarns is offline
FRC #4049
dcarns is an unknown quantity at this point
I've been searching for this update but I've been unable to find it. We're having the same issue so if you could send me a link to the update it would be much appreciated! thanks
Unread 22-01-2016, 12:31
FRC #0237
We just released it:
https://github.com/WPIRoboticsProjec...eleases/latest
