Go to Post And who is to say what is the mean? Do I mean the mean? Or even the average? Or am I just being mean (or average, which could be my mean)? - dlavery [more]
Unread 16-01-2016, 12:40
Charles Doherty Charles Doherty is offline
FRC #5822
Charles Doherty is an unknown quantity at this point
Tape Measure Winch
In other First competitions, some robots have used a tape measure winch, to lift or propel itself. Below are some videos that we have looked at. Does anyone have an idea on how to build something like this? Currently, we are considering two wheels feeding the tape out. It would also be helpful if you have pictures or CAD files.
Charles Doherty
Team 5822
Tape Measure Winch
https://www.youtube.com/watch?v=ghuWhsQecFw
https://www.youtube.com/watch?v=jhdRaQZrORM
http://www.chiefdelphi.com/media/img...c3203416_m.jpg
https://www.youtube.com/watch?v=WlSa4RQkxsE
https://www.youtube.com/watch?v=YJn3G7iRkTM
Unread 16-01-2016, 12:44
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Re: Tape Measure Winch
I believe last year 842 used tape measures for their can burglars, so you may want to take a look at that.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 16-01-2016, 13:03
FRC #5822
Thanks KohKoh. Ill look into it.
-Charles Doherty
5822
Unread 16-01-2016, 13:47
*Rachelle*'s Avatar
*Rachelle* *Rachelle* is offline
Coach, Scout Captain, Marketing
FRC #3787 (Wild Robotocats)
Team Role: Student
*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of
If you guys want to use a tape measure winch, you may want to keep in consideration the rule update (Update 2, page 2) that shows examples of robots climbing and keeping their appendages within 15 in. of their frame perimeter.
2015 Glacier Peak and Shorewood Event Quality Award
2015 Shorewood Finalist
3x 2015 Pit Safety Award and Hard Hat Pin Award
"You have to learn the rules of the game. And then you have to play better than anyone else."
Albert Einstein
Unread 16-01-2016, 14:51
hubcappancake's Avatar
hubcappancake hubcappancake is offline
AKA: Cole
FRC #3189 (Circuit Breakers)
Team Role: Human Player
Rookie Year: 2015
hubcappancake is an unknown quantity at this point
Charles Doherty
Team 5822
Tape Measure Winch
can you post a close up of your winch
Unread 16-01-2016, 15:32
AKA: Daniel Koh
-Charles Doherty
5822
No problem. However, I realized a tape measure may not work as well due to its structural instability. I believe the way 842 does it is they use a high-grip wheel to reel out the tape measure. That being said, it would be easy to extend the tape measure, but lifting ~150 lbs to the desired height would be a challenge.
If your team has the resources (I don't know because 5822 sounds like a rookie team), then I would strongly suggest to think of some other, more robust solution to the climb. Consider what teams did during 2013 Ultimate Ascent
-KohKoh
Unread 16-01-2016, 15:58
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Make sure to test the tensile strength of the tape measure with the hook solidly attached. FRC robots can easily weigh 120 lb+ so I'd just be weary of something snapping or breaking. For more strength you could maybe even add a second tape measure facing the opposite way so the tapes don't "fall over" when they're extending. I've never seen a tape measure used for climbing on this scale but I think it'd definitely be cool to see someone go for it
Unread 16-01-2016, 16:01
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
The tape measure system that us and 842 built last season is documented here.
The requirements are a little different for a climber though...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-01-2016, 16:22
JohnFogarty's Avatar
AKA: @doctorfogarty
Except a rookie team was the first to do it. 3280 was a rookie team in 2010.
3280 did it in 2010 and made it look easy. Granted the method wouldn't be allowed to work the exact same way as you will see in the video the robot flipped end over end which as of update 2 is clarified as illegal.
I still think there are 2 other options for deploying tape measure climbers that won't flip a robot that will employ this simple and effective device. The first and most obvious for most teams to consider is mounting their tape measure climber near the COG of their robot thus potentially keeping the robot level as it ascends.
John Fogarty
Unread 18-01-2016, 03:18
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Actually, not the first.
FRC 766, 2015-, Mentor
Unread 18-01-2016, 17:07
Vyrotek's Avatar
Vyrotek Vyrotek is offline
AKA: Jason
FRC #0498 (Cobra Commanders)
Vyrotek is an unknown quantity at this point
Yep. Super important. We almost went down this route. This ruling killed most winch ideas since your bot cannot tip and pull itself up.
