Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 17-01-2016, 23:26
Boltman Boltman is online now
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Is Bowling thought the Low Bar legal
Originally Posted by rich2202 View Post
Instead of the robot holding the cloth, how about the robot in the shape of a wedge, and the boulder "hits" the robot and "bounces" over the low bar?
Legal currently however at any time they could pull the "intent of game" clause like they did for holding low bar carpet up by bot. I would not count on that strategy.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-01-2016, 07:39
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Originally Posted by Chak View Post
Similar to the OP's solution, I think that this would probably be physically impossible.
Even if you figure out a way to do it, this robot would be violating G40.
You would receive a tech foul per boulder, unless this robot follows every boulder through the defense. In that case, any robot with an effective floor intake would be able to perform the same function in a more feasible way.
If the bot is in the outerworks (in order to contact in the outerworks zone), 4 boulders are bowled, and then the robot drives through to the other side before any other bot touches a boulder.
Unread 18-01-2016, 14:07
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
G40 starts with "A ROBOT may not cause a BOULDER....". "a BOULDER" is singular, and it then goes on to state the required conditions. If you deflect multiple BOULDERS into COURTYARD you are violating the conditions (did not complete the CROSSING) and incur a TECH FOUL per BOULDER.
Also, G40-1 was added to clarify the intent, that only ROBOTS can move BOULDERS, one at a time, into the COURTYARD. This also came up in the Q&A.
Unread 18-01-2016, 14:35
Dylan179's Avatar
Dylan179 Dylan179 is offline
FRC #0179 (Children of the Swamp)
Dylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud of
If a human player where to enter the ball in fast enough and get it over the ramp parts in slot 2 (next to the low bar) is it legal?
Unread 18-01-2016, 14:41
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
As the rules currently stand? Yes. Is it against the intent of the rules? Yes. Also, I would play around with the physics of the field, but I don't actually think it's possible to get an angle on the Ramparts from the Embrasure from the HP station.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 18-01-2016, 16:40
Design and Fab guy
AKA: Brad Warkentin
As the rules stand right now (after update 2) it is legal. The only rule regarding the HUMAN PLAYER and BOULDER interaction is G33, and there are no restrictions on where the BOULDER has to end up, just how it has to enter the FIELD. There have been claims that some HUMAN PLAYERS have been able to kick the BOULDERS over the DEFENSES into the COURTYARD, which also is currently legal. I suspect this will prove to be difficult and very inconsistent.
However, there is no guarantee that the RAMPARTS are going to end up next to the LOW BAR, and realistically if any team thinks anyone can bowl through there they are going to select a different DEFENSE that is harder to bowl over. Remember, per section 5.5.10, the opposing ALLIANCE chooses the DEFENSES in slots 2,4,and 5 and they have control which choice goes where.
