Go to Post Now that football is over... ARE YOU READY FOR SOME ROBOTS?!?! - KelliV [more]
Unread 18-01-2016, 09:56
ImOn3618 ImOn3618 is offline
AKA: Ethan Hammond
FRC #3618 (Petoskey Paladins)
ImOn3618 is a jewel in the roughImOn3618 is a jewel in the roughImOn3618 is a jewel in the rough
Bumper "Side" Clarification
The rules read
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER.
For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside
corner (see Figure 4-3). If a side is shorter than 8 in., the entire side must be protected by
BUMPER (see Figure 4-4).
I have attached what we are currently hoping is alright and the drawing most closely describing our situation from the game manual. We are thinking that the end of our chassis would constitute a side and therefore the whole thing must be covered by bumper. It is shorter than 8 inches though and we are concerned that the bumper still must be 8 inches. We don't think that we will be forced to extend our bumper given that there will be no frame chassis or support after that 5 inches in the attached picture. This is an issue because if the bumpers have to be 8 inches the robot has to be 26 inches wide to intake a ball not over a bumper.
Name:	Bumper Explaination.JPG
ID:	19790  Click image for larger version
Name:	Rule Drawing.JPG
Unread 18-01-2016, 10:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper "Side" Clarification
The bumper needs to be at least 8" long. You need to support it, as shown in the rules. Your idea of having short bumpers like that (which has been asked about by countless other teams) won't pass inspection. Sorry.
There might be another way to get the BOULDER in there...think about it....
Unread 18-01-2016, 10:03
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
And just to reiterate, the side with the opening still has a frame perimeter of 24 inches. The calculation of the frame perimeter doesn't required a actual frame.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 18-01-2016, 10:04
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
If this is a top view, the edge of your FRAME PERIMETER is the 24 inch dimension and therefore you have to cover 8 inches on either side. The bumper shown would not be legal.
See this Q&A
If in doubt, imagine pulling a string all the way around the outside of your robot. This defines your FRAME PERIMETER. Each of the sides of string now needs to have at least 8 inches of bumper on it, and each end of each bumper piece needs to be supported (at least 1/2 inch per R26).
-matto-
Unread 18-01-2016, 10:06
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
To further clarify for you, as shown in the diagram, you have only 5" of bumper protecting the frame perimeter...the 3" outside the frame perimeter does NOT count towards the 8" required
"A genius is just a talented person who does his homework" T. Edison
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The manual drawing you have attached is clearly just like your planned robot. You'll note the black rectangle drawn on it marked FRAME PERIMETER. The FRAME PERIMETER is the thing that has sides that need to be covered. In the manual drawing, the short bumper on the side with the U cut in it is at least 8 inches long. Your bumper must also be 8 inches long because each corner of the frame perimeter must have at least 8 inches of bumper on either side of it.
In short, your CADed drawing is illegal because the bumper needs to be at least 8 inches. And yes, this does mean your robot must be 26" wide to intake a ball through the bumpers.
Unread 18-01-2016, 10:24
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
ImOn3618,
I edited your CAD image to show what you'd have to do to follow the bumper rules, if you were to keep a width of 24 inches (see attached). You are correct in saying that the gap between the bumpers is not wide enough to fit a boulder. But, as you said, if you increased the robot's width to 26 inches, the gap would become 10 inches, which is the diameter of a boulder. Hope that helps.
Unread 18-01-2016, 12:21
WBCSaint's Avatar
WBCSaint WBCSaint is offline
FRC #4488
WBCSaint is an unknown quantity at this point
R19 states: If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-4)
The way I read that, is you are allowed to have a side less than 8" as long as the entire side is covered by a bumper. I could be wrong about the way I am reading that part of R19.
Unread 18-01-2016, 12:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
A side with a gap in the middle isn't considered 2 sides. It's one side and the gap can't be more than 8 inches from a corner on either side.
Unread 18-01-2016, 12:25
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
The side is not just the part with the frame. The side of your robot includes the opening for intake. Therefore the side is not 5 inches. It's 24 inches. Which means 8 inches from each corner must be covered.
EDIT: In the image this highlighted part is the answer to your questions.
Name:	Rule Drawing edit.JPG
Unread 18-01-2016, 12:27
Before anyone suggests it, no, tilting/turning those short bits of frame on either side of the U cut-out won't help. It will create a new shorter side right where the cut-out is. The two corners of that new side will need 8" of bumper as well, further covering up the U cut-out.
Unread 18-01-2016, 17:36
GaryVoshol's Avatar
Cogito ergo arbitro
The picture from the manual that was posted with a gap in the frame does NOT have 5 sides. It has 4 sides. A side goes from corner to corner, not from corner to gap.
(since 2004)
Unread 19-01-2016, 22:45
WBCSaint's Avatar
FRC #4488
So does the 8" of bumper have to be continuous? Or if you had a 4.5" section of bumper, then you use the Rhino bumper kit to have the rest of the 3.5" of bumper raised, would that still count as your 8" of bumper coverage?
Unread 19-01-2016, 23:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Kevin Sevcik View Post
..your robot must be 26" wide to intake a ball through the bumpers.
These balls are pretty squishy. You could get them through a much narrower passage if needed. (That said, we're lifting the ball over a continuous solid frame perimeter, using a gap in the bumpers to help keep things tight and low.)
I don't see anything forbidding this. Bumpers are not required to all be at the same height, or even horizontal along their length. However, given the hardware required to mount this, it would probably be easier and lighter to raise the whole corner.
Unread 19-01-2016, 23:46
MrForbes's Avatar
AKA: Jim
I guess no one figured out why the maximum bumper height is 12" this year...sigh....
