Go to Post Word of advice:Don't eat a whole box of nutrigrain bars that are loaded with fiber in one sitting...Yeah.. Bad thing. - Elgin Clock [more]
Unread 15-01-2016, 09:35
ben47955 ben47955 is offline
FRC #3996
ben47955 is an unknown quantity at this point
radio configuration
I have try to config the new radio, but when i lunch the FRC Radio Configuration , i don't show any network interfaces, but I can acces to radio in navigator. I have try many PC, many cable and all time the same problems, thanks for your help.
Unread 15-01-2016, 09:53
ahaltom ahaltom is offline
FRC #5712
ahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of light
Re: radio configuration
Hello,
I followed this guide directly from the Andy Mark webpage.
http://files.andymark.com/OM5P-AN_QuickAP_Setup.pdf
The process was extremely smooth. If you have trouble, let me know and I may be able to assist.
Unread 15-01-2016, 10:34
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Here is another set of instructions for using the standard FRC Radio Configuration Utility for this year. Notice it is not installed with the LabVIEW update this year.
http://wpilib.screenstepslive.com/s/...o-for-home-use
What do you mean by navigator? Have you tried disabling your firewalls?
Unread 15-01-2016, 10:57
FRC #3996
I can confire the radio at 192.168.1.1 but in FRC Radio Configuration, I see this :
Unread 15-01-2016, 11:14
What Operating System do you use? Do you have the latest version of Java? Try disabling your computer's firewall. You should be able to see the network interfaces without being connected to the radio.
Unread 15-01-2016, 11:18
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Maybe you need to run as Admin?
Check your Network Connections and make sure your network connection is enabled.
Control Panel\Network and Internet\Network Connections
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 15-01-2016, 11:40
FRC #3996
I uses win 7 x64 and I have disable the firewall and connection is enable, I have java but i'm not sure if is really active.
Unread 15-01-2016, 12:08
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
what worked for us:
-Run as Admin
-ethernet cable connected to the edge of the router, not the middle one
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 15-01-2016, 12:13
FRC #3996
Originally Posted by MaGiC_PiKaChU View Post
what worked for us:
-Run as Admin
We do this, but we have always the problems.
Unread 18-01-2016, 10:44
My guess is that the configuration tool is not happy with a French-localized version of Windows.
Unread 18-01-2016, 15:41
FRC #3996
Finally windows in french is the problems, but now, i have this new error message :
