Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 18-01-2016, 10:50
mark219 mark219 is offline
Programmer/Driver
AKA: Mark Szewczuk
FRC #0219 (Team Impact)
Rookie Year: 2015
mark219 is an unknown quantity at this point
Autonomous Not Working
Hello, sorry to be posting yet again, but this time it's another problem. I'm trying to get autonomous to simply just drive, not in a straight line, but just drive in general. The rio doesn't throw me any errors or anything, just nothing happens when I run my autonomous command. Here's my code
Drive subsystem
package org.usfirst.frc.team219.robot.subsystems;
import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Drive extends Subsystem{
	private final int MOTOR_PORT_FL = 1;
	private final int MOTOR_PORT_BL = 2;
	private final int MOTOR_PORT_FR = 4;
	private final int MOTOR_PORT_BR = 3;
	CANTalon talonFL = new CANTalon(MOTOR_PORT_FL);
	CANTalon talonBL = new CANTalon(MOTOR_PORT_BL);
	CANTalon talonFR = new CANTalon(MOTOR_PORT_FR);
	CANTalon talonBR = new CANTalon(MOTOR_PORT_BR);
	//RobotDrive robotDrive = new RobotDrive(talonFL,talonBL,talonFR,talonBR);
	@Override
	protected void initDefaultCommand() {
		// TODO Auto-generated method stub
	//command for auton drive
	public void driveLR(double leftSpeed, double rightSpeed){
		setTalonSpeed(leftSpeed,rightSpeed);
	public void setTalonSpeed(double leftSpeed, double rightSpeed){
		talonFL.set(leftSpeed);
		talonBL.set(leftSpeed);
		talonFR.set(rightSpeed);
		talonBR.set(rightSpeed);
autonomous drive command
package org.usfirst.frc.team219.robot.commands;
import org.usfirst.frc.team219.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class AutonDrive extends Command{
	@Override
	protected void initialize() {
	@Override
	protected void execute() {
		Robot.drive.driveLR(.25, .25);
	@Override
	protected boolean isFinished() {
		return true;
	@Override
	protected void end() {
	@Override
	protected void interrupted() {
Robot Class
package org.usfirst.frc.team219.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import org.usfirst.frc.team219.robot.commands.AutonDrive;
import org.usfirst.frc.team219.robot.subsystems.Drive;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	public static OI oi;
	public static final Drive drive = new Drive();
    Command autonomousCommand;
    SendableChooser chooser;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
		oi = new OI();
        chooser = new SendableChooser();
        chooser.addDefault("Auton Drive", new AutonDrive());
//        chooser.addObject("My Auto", new MyAutoCommand());
        SmartDashboard.putData("Auto mode", chooser);
     * This function is called once each time the robot enters Disabled mode.
     * You can use it to reset any subsystem information you want to clear when
	 * the robot is disabled.
    public void disabledInit(){
	public void disabledPeriodic() {
		Scheduler.getInstance().run();
	 * This autonomous (along with the chooser code above) shows how to select between different autonomous modes
	 * using the dashboard. The sendable chooser code works with the Java SmartDashboard. If you prefer the LabVIEW
	 * Dashboard, remove all of the chooser code and uncomment the getString code to get the auto name from the text box
	 * below the Gyro
	 * You can add additional auto modes by adding additional commands to the chooser code above (like the commented example)
	 * or additional comparisons to the switch structure below with additional strings & commands.
    public void autonomousInit() {
        autonomousCommand = (Command) chooser.getSelected();
		/* String autoSelected = SmartDashboard.getString("Auto Selector", "Default");
		switch(autoSelected) {
		case "My Auto":
			autonomousCommand = new MyAutoCommand();
			break;
		case "Default Auto":
		default:
			autonomousCommand = new ExampleCommand();
			break;
    	// schedule the autonomous command (example)
        if (autonomousCommand != null) autonomousCommand.start();
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
    public void teleopInit() {
		// This makes sure that the autonomous stops running when
        // teleop starts running. If you want the autonomous to
        // continue until interrupted by another command, remove
        // this line or comment it out.
        if (autonomousCommand != null) autonomousCommand.cancel();
     * This function is called periodically during operator control
    public void teleopPeriodic() {
     * This function is called periodically during test mode
    public void testPeriodic() {
        LiveWindow.run();
Unread 18-01-2016, 12:01
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Autonomous Not Working
Well just from looking at the command (assuming its running properly), you're running it for a total of 0 seconds (because you're instantly returning "true" for "isFinished"). I'd recommend a setTimeout() and isTimedOut() (? don't remember the name of these functions, its been two years since ive done command based programming) to set the command to a specific time interval.
Also, there's no evidence that you ever tried to debug the issue. I recommend that you post System.out.println() calls to trace where your code is running to detect where your issue is. Is the command being initialized properly? Is isFinished() being called? Is execute() being called? Are the talons valid? Chief can't help you competition-time.
Unread 18-01-2016, 12:29
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
i'd try putting false in the isFinished method, then set your motors to 0 in isInterupted and isFinished. You should drive until teleop kicks in
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 18-01-2016, 13:10
Programmer/Driver
AKA: Mark Szewczuk
Rookie Year: 2015
Thank you for your input everyone, however this time it wasn't a code issue, but a hardware issue. Our CAN bus wires got unplugged from the roborio which caused the values to not be sent to the motors.
