Go to Post The Pet Rock was very original, but not necessarily a great thing. - IKE [more]
Unread 01-16-2016, 11:49 AM
mark219 mark219 is offline
Programmer/Driver
AKA: Mark Szewczuk
FRC #0219 (Team Impact)
Rookie Year: 2015
mark219 is an unknown quantity at this point
No RobotCode
The programming team and I are currently working with a small test robot we built in the preseason. So far, we have been able to make the robot and make a simple drive system so it can drive based off of user input from a controller. Recently, we re-imaged and re-installed a new JRE onto the roborio that our test robot has to the new 2016 image/jre. Previously, our code would work, now it doesn't and we don't now why?
Here is the console log on eclipse
Buildfile: C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build
   [delete] Deleting directory C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\dist
compile:
    [mkdir] Created dir: C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\RM316CSHP2/wpilib/java/current/lib/WPILib.jar:C:\Users\RM316CSHP2/wpilib/java/current/lib/NetworkTables.jar: to build
    [javac] Compiling 6 source files to C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\dist
    [mkdir] Created dir: C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\RM316CSHP2/wpilib/java/current/lib/WPILib.jar:C:\Users\RM316CSHP2/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
     [copy] Copying 2 files to C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\build\jars
      [jar] Building jar: C:\Users\RM316CSHP2\Desktop\Robotics\Run-Motor\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-219-FRC.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-219-FRC.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-219-FRC.local:22
      [scp] done.
  [sshexec] cmd : killall -q netconsole-host || :
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] killall: lvrt: no process killed
  [sshexec] Remote command failed with exit status 1
  [sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 14 seconds
and here is the RioLog output (there's a load of these messages oncoming every 2 seconds or so)
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
execvp: No such file or directory
What I think is that this means that there is no JRE on the rio, however we did successfully install it (or so the person who did it said so)
Unread 01-17-2016, 02:23 PM
robobot14 robobot14 is offline
robobot14 is an unknown quantity at this point
Re: No RobotCode
We have actually just finished debugging this problem. We solved the problem by re-downloading the JRE and make sure that it is the ARMv7 Linux - VFP, SoftFP ABI, Little Endian version (the second one on the list that pops up). Hope this helps.
Unread 01-17-2016, 06:32 PM
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Re: No RobotCode
Can you link the list you are talking about?
Unread 01-17-2016, 08:41 PM
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Re: No RobotCode
Image from Screensteps.
Unread 01-17-2016, 09:01 PM
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
Re: No RobotCode
That stepped hosed us up a bit too the other day. The "browser" in the provided wizard wouldn't play nicely with creating a new account and then letting us download it. It just didn't work. Also, going directly to Oracle's website we couldn't find the link to "ARMv7 Linux - VFP, SoftFP ABI, Little Endian version" so we used the installer wizard (the one shown in the screenshot) to get to the right page, right clicked the link, copied the URL, then opened up Chrome and used that to login to Oracle and then just pasted the URL into the address bar. Viola! We had our proper JRE... then used the wizard to install it by backing up to the start of it all and pointing it to a local file.
Unread 01-18-2016, 11:29 AM
Programmer/Driver
AKA: Mark Szewczuk
Rookie Year: 2015
Re: No RobotCode
Thanks all, it turns out we put the wrong JRE onto our roborio. Got the right one and it worked fine!
