Go to Post All this community stuff is actually pretty fun! :) - JBotAlan [more]
Unread 18-01-2016, 12:12
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Error trying to install FRC Update Suite 2016
Is that space in the installation directory usually there?
Try extracting the update suite to C:\ and running it from there.
Did you extract everything from the .zip file into a new folder first? Running the setup program from inside the .zip does not work.
Based on the error given, he did indeed extract it because if he did not, the exe would have been run from a C:\...\AppData\Local\Temp\7xxxxxx directory
