Go to Post FIRST is not a party. It is the most important activity a high school age student can do. - JohnBoucher [more]
Unread 18-01-2016, 13:00
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Aiming with Vision
Originally Posted by Greg McKaskle View Post
When I is set to zero, the code has a special case for P and PD. When you say it doesn't output anything, do you mean it doesn't complete, always returns zero, or something else?
Greg McKaskle
I'll do some more testing when I get back to the shop, but AFAIR, it outputs 0
2015 MAR District Champions
Unread 18-01-2016, 14:48
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
So dubiousSwain, you used both RoboRealm and the Vision Assistant? What 'algorithm' did you perfect in RoboRealm?
Unread 18-01-2016, 17:44
The ride never ends
We have two programmers on our team, so we decided to split up and research different approaches. I worked on blob filtering in RoboRealm, while my teammate Billy worked on pattern matching in the Vision assistant, a la 900. I made much quicker progress on the blob filter, and it gave good results, so we ported the pipeline into the vision assistant and had it build the VI. We decided that socketing into roborealm would not be as reliable as running a VI robot-side or using NT dashboard-side
tl;dr, we are not using both Roborealm and Vision Assistant, we tested both and then decided to use the VA.
EDIT: By algorithm I mean Pipeline.
Unread 18-01-2016, 17:48
FRC #4206
Oh. Okay. We only have one programmer, me, so the quicker I can settle on something the better. I guess I'll stick with Vision Assistant. Thanks!
Benjamin
Unread 18-01-2016, 17:52
The ride never ends
Benjamin
The key for vision assistant is to take as many test images as you can, in all kinds of lighting. You can do this by pausing the live stream at 10.42.06.20 and right clicking "save as". Make sure its paused, or your computer will not open the dialogue box and continuously acquire images.
Please PM me if you have any trouble, it can be tricky to figure out
Unread 18-01-2016, 18:07
FRC #4206
Okay. Thanks! Do I use all the images to test it, or somehow factor them all in as images to look for in Vision Assistant? Sorry for my inexperience, I've never used it before, and I haven't yet had the chance to play around with it.
Unread 18-01-2016, 20:54
The ride never ends
There is an option in the file menu to import images. Just shift select all the images you saved and it will import them all. then use the green arrows above the pipeline or the grey arrows to the left to move through them.
Unread 19-01-2016, 10:07
FRC #4206
Okay. Thanks. I'll be trying that soon.
