Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 15-01-2016, 09:00
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: [Ri3D] Team Indiana Presents: Veronica
Once again, probably the best Ri3D team. You guys have set the standard for a strong Stronghold robot. Do you have CAD for the bot you can post? I'm curious to see how you got that shooter crammed in there.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-01-2016, 09:15
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Originally Posted by nxtmonkeys View Post
Can you make it jump-hang?
This question makes me want to run the math for the situation where the Shovel the fries™, is in the middle position to find the speed the robot would have to carry to make it to the bar...
Thanks. We'll be posting a 3D pdf as well as some other resources, but not a full CAD.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 15-01-2016, 09:37
Professional Stat Padder
Originally Posted by Logan Byers View Post
Our shooting sweet spot is right in front of the tower, with wheels touching the BATTER (base of the tower). Ideally, we'd beat the defense to the spot and take away the chance of the defense blocking our shot. The video of us shooting from farther away was taken during prototyping. An issue we saw with shooting from a distance was the difference in compression between a fresh boulder and a used boulder, which affected shot performance.
Can you give some examples of how the wear affected shot performance? How much wear are we talking about?
That makes me nervous. 5254 and 20 haven't tested with worn balls yet because both teams have only one ball right now.
(2015-Present)
Unread 15-01-2016, 10:07
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
If I was to guess, it was somewhere around 50 shots. We dialed in the prototype shooter until it worked with one ball, then we tried another ball, which flew completely over the goal.
The foam directly under the skin "crumples" slightly after many shots. You can feel the difference when you squish them by hand.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 15-01-2016, 16:39
slhs slhs is offline
FRC #4639
slhs is an unknown quantity at this point
What was the length of each pieces of the double jointed arm?
Unread 15-01-2016, 16:44
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
So the curse of 2012 strikes again. Hopefully FIRST doesn't decide to source from a new manufacturer midway through the season this year as well.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 15-01-2016, 16:47
Ben Martin's Avatar
I don't remember the exact number, but it's pretty easy to calculate--subtract the height of your mounting location from the height of the drawbridge, then divide by 2 and add a few inches to account for the joint and a bit of extra space for the drawbridge grab.
Unread 16-01-2016, 15:05
Purpose's Avatar
Purpose Purpose is offline
President
AKA: Victor A
FRC #0834 (Spartechs)
Rookie Year: 2015
Purpose will become famous soon enough
Great job Indiana, I love how versatile your bot is, and the fact that it has bumpers makes it even better. Just curious, do you happen to know what gear ratio you're using for the treaded bot's transmissions? The speed and power balance looks perfect from your videos. Thanks a bunch!
Unread 16-01-2016, 20:53
Nathan M's Avatar
Nathan M Nathan M is offline
Team Captain
FRC #0865 (Warp 7)
Nathan M is on a distinguished road
This robot looks great! I was wondering if your close shot is taken hard stopped on the tower or a few inches away? I couldn't tell from the video.
Unread 16-01-2016, 23:05
Danny Blau's Avatar
Danny Blau Danny Blau is offline
50% of life spent in FIRST!
no team (AndyMark)
Danny Blau is a jewel in the roughDanny Blau is a jewel in the roughDanny Blau is a jewel in the rough
Thanks!
We were shooting with our back wheels resting on the hard stops at the bottom of the castle ramps. This proved to be a very effective and reliable place to shoot from. We had also talked about deploying an outrigger to the front of the robot to give us an even more consistent, undependable shooting location.
AndyMark Inc
Design Engineer, FTC Project lead
Unread 17-01-2016, 00:42
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Great job on the robot! I was just wondering, why did you end up deciding to use a pneumatic wheel drive train instead of the Rhino tracks?
Unread 17-01-2016, 09:32
PurpleInk PurpleInk is offline
Mrs. BoilerMentor
AKA: Betsy Baxter
FRC #1747 (Harrison Boiler Robotics)
PurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant future
We were asked this all through our 3 day build so we covered it in the Q & A:
https://m.youtube.com/watch?v=PrgI7NRyqbY at about 8:20:20
They did a great job of explaining our reasoning there
Betsy
FIRST Team 1741 - Student 2005 - 2007
FIRST Team 1741 - Mentor 2007 - 2012
BoilerMentor Asks Me to Join His Alliance
FIRST Team 1747 - Mentor 2012 - Present
Ri3D Team Indiana - 2015 - Present
Unread 17-01-2016, 16:47
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Did you discuss the impact of used balls vs fresh balls elsewhere on a video that we could go back and reference?
How much compression were you getting on your balls? (distance from shooter wheel surface to curved backplate)
Thank you for your insights! :-)
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 18-01-2016, 10:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Were the stealth wheels able to manage a long-distance shot in such a short acceleration arc? Approximately how much compression was the ball under while in the shot arc?
Trying to get a 4" diameter wheel to get any distance, even with equal wheel edge speeds as larger wheels, has been ... challenging...
GitHub
Unread 18-01-2016, 13:26
swicki's Avatar
swicki swicki is offline
AKA: Gavin
FRC #2152 (S*M*A*S*H)
swicki will become famous soon enough
Any update on the 3D pdf?
