Go to Post Obviously, really large issues need to be addressed, and if you feel there is a huge problem, by all means, go ahead, if you can be polite, productive, and graciously professional, address it. - Amanda Aldridge [more]
Unread 18-01-2016, 14:16
ultradan's Avatar
ultradan ultradan is offline
Team #3550 Robotronics
FRC #3550 (Robotronics)
ultradan is an unknown quantity at this point
Talon SRX PWM vs encoders
Hello from 3550 !
We will use the new Talon SRX c/w PWM controls and we want to use the quadratic encoders E4T directly on the talon. The programmers wants to know if they will have access to the encoders datas with the software thru the PWM.
Electrically we know how to connect the sensor to the data port...but how to handle the datas ( and reset, etc...).
In the Talon SRX software manual. it says all about programming but is it only when used in CAN connection mode?
thanks,
Unread 18-01-2016, 14:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Talon SRX PWM vs encoders
Closed-loop control is only available when using the CAN bus.
Unread 18-01-2016, 14:47
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
If you're using PWM for the Talon you're probably better off using the RoboRio for PID control. However, using the Talons via CAN is dead easy, and the internal PID control isn't too difficult to implement and works well.
PM me and I can come to Cavelier to help out if you like.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 18-01-2016, 15:54
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Hey ultradan,
The functions and examples in the Talon SRX Software Reference Manual assume the sensor is connected to the Talon. This applies to the closed-looping features, and the various getters/setters.
Is there a specific reason you are using PWM?
If the goal is to connect the sensor to the Talon directly, then wiring the Talon the the RIO CAN port is required.
Unread 19-01-2016, 10:58
ultradan's Avatar
Thanks all for your advise.We'll give a try tonight for the CAN bus & encoders on our demoplateform. JC: thanks for the proposal - I'll be at Cavelier tuesdays PM after 5PM and some thursday PM.
Unread 21-01-2016, 18:28
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Hey - 668 is looking for an example of CAN Talon internal PIDs with an encoder on the Talon itself. We (and other teams I'm sure) would like to hear of your results. Thanks!
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
