Go to Post Mark McLeod, one of the resident experts on compiler weirdness - Kevin Watson [more]
Unread 18-01-2016, 19:17
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Driving up the portcullis
Has anyone tried driving your robot up to the portcullis and putting a driven wheel in contact with the gate, then driving the gate up and the robot under?
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 18-01-2016, 19:34
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Rookie Year: 2015
Robomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to behold
Re: Driving up the portcullis
Have not tried. How do you get a drive wheel in front of your bumper?
Unread 18-01-2016, 19:36
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
A driven wheel is a wheel powered by a motor. Such a device would be allowed as long as it is not extended horizontally more than 15" beyond the frame perimeter and is not extended above the height limit of the robot.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 18-01-2016, 20:37
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
1452-Leo is an unknown quantity at this point
We built a portcullis out of wood (built to the "Team Version" specifications) and I don't think it would be possible to roll it up. However, the actual one might have less friction when applying a force perpendicular to the lexan, so it might be easier.
Unread 18-01-2016, 21:05
RoboChair's Avatar
AKA: Devin Castellucci
The portcullis uses ball bearings at the top and bottom of the door in a steel track. So even with huge side loads there should be very little friction(page 253 of 2016FieldComponents.pdf)
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-01-2016, 21:11
Bob Steele's Avatar
AKA: Bob Steele
bearings at the top and bottom... Not sure i understand...
Do you mean the top and bottom of the sides? Probably ...
Unread 18-01-2016, 21:19
RoboChair's Avatar
Yes, on the sides in a steel track. Consult the 2016FieldComponents.pdf for a visual of the Portcullis as you will see at competition.
Unread 20-01-2016, 07:12
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
We've had the same idea too. There are ball bearings on the sides at the top, and I believe a wheel at the bottom that will roll along a track.
You should allow for more than 5lbs of force - motors should generally be run at under 50% of maximum torque and you should account for some friction too.
Please post back and let me know how things work for you.
Unread 20-01-2016, 07:26
TheGabe's Avatar
TheGabe TheGabe is offline
FRC #1259 (Paradigm Shift)
Team Role: CAD
TheGabe is an unknown quantity at this point
Our team tried this. We have a few of the four inch anymark wheels (checkered tread) on the frount of our intake mechanism. We decided to try it. Only about half of the wheel is exposed toward the gate so we were able to roll the gate up and it rested on top of our wheels. From there we lifted the intake mechanism up and drove under. Our portcullis is made out of wood and has the 5lb lift force. This is how we plan on tackling this defence during competitions.
Unread 20-01-2016, 08:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Great to hear it! We're also planning to double-duty our intake rollers to raise the portcullis. Better go back and check the forces, though!
