Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 18-01-2016, 19:09
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Red Robot Code Indicator
So, my team bough a second roboRio this year so that we can have a separate board for programmers, and we have been having a lot of issues with it. When we power cycle the rio and deploy code, there is an exit status 1 error below:
Buildfile: C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build
[delete] Deleting directory C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\dist
compile:
[mkdir] Created dir: C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\robotics/wpilib/java/current/lib/NetworkTables.jar: to build
[javac] Compiling 1 source file to C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\dist
[mkdir] Created dir: C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build\jars
[echo] [athena-jar] Copying jars from C:\Users\robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\robotics/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
[copy] Copying 2 files to C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\build\jars
[jar] Building jar: C:\Users\robotics\git\Robot2015Recycle\Robot2016\T ank Drive\dist\FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-2141-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-2141-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-2141-FRC.local:22
[scp] done.
[sshexec] cmd : killall -q netconsole-host || :
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] killall: lvrt: no process killed
[sshexec] Remote command failed with exit status 1
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 10 seconds
We assume that this just means there isn't any code running on the rio, since it just power cycled, because when we deploy code a second time, there is no error.
However, the main issue we have is that on the driver station, the Robot Code indicator is red, even when there is communication. At no point have we seen it turn green, even when we deploy sample projects. We have reimaged and reupdated the firmware for the rio multiple times. The plugins are up to date. Any help would be appreciated.
Unread 18-01-2016, 19:18
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Red Robot Code Indicator
is there any NetConsole/RioLog or ds log feedback?
Unread 18-01-2016, 19:29
Rookie Year: 2015
The Riolog has this message continuously repeating:
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
execvp: No such file or directory
We tried downloading the JRE to the rio, and we got this message:
java.io.IOException: Error when setting permissions on executables 1
