Go to Post Realizing your DON'T want to be an engineer is every bit as important as realizing you do - Lil' Lavery [more]
Unread 18-01-2016, 20:00
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: FRC 2016 Q&A Link not working
Originally Posted by slibert View Post
I'm trying to access the FRC 2016 Q&A system via the link (http://frc-qa.firstinspires.org/Questions.php) that's on the FRC website.
Can anyone please post a link to the FRC 2016 Q&A system that actually works?
Are you using the login information from your team's TIMS page?
Unread 18-01-2016, 20:03
slibert slibert is online now
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
I'm using the http://... link from the usfirst public website. This link doesn't work and I've notified FIRST.
The https://... link does work.
Thanks for your help.
Unread 18-01-2016, 20:42
Not everybody has access to the Q&A. It is password protected so as to make sure only a couple of folks from each team have access in an attempt to make sure that questions are discussed internally before being posted. Were FIRST not to do this, they would be overwhelmed with questions - more than they could possibly answer... The primary contacts on your team can easily find the login information by signing in to their TIMS account... The password is in a list of all sorts of goodies -such as FirstChoice, etc.
Unread 19-01-2016, 11:05
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not everybody has access to the Q&A....
Everybody can see the posted questions & answers. You only need to log on ask a question. The link to Q&A was bad from the firstinspires web site this morning.
