Go to Post I never said there was anything wrong with the kit frame, simply that it was weak. - Viper37 [more]
Unread 18-01-2016, 20:00
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Motor Used for Shooting
Just curious as to what motors people are using to siege the opposing towers with. With the unlimited-ness of non-CIM motors, what are people going for?
Academic Student (Forever)
Unread 18-01-2016, 20:02
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: Motor Used for Shooting
We haven't finalized anything, but we've been prototyping with a CIM.
Unread 18-01-2016, 20:04
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
775pro at 2:1 ftw
Unread 18-01-2016, 20:50
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Do you mean for shooting/throwing boulders or for climbing?
Unread 18-01-2016, 20:57
CalTran's Avatar
Missouri S&T Senior
Title says shooting. I guess siege has 2 meanings this game...
Unread 18-01-2016, 20:58
Drive Coach
AKA: Alex Dalziel
Team Role: Driver
Apologies, it clearly says in the thread title.
775Pro motors are working very well for us
Unread 18-01-2016, 21:02
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
We've so far been pretty successful using 775pros on a 4:1 versaplanetary gearbox with 4" wheels at ~4500RPM (max rpm for this setup). Once the stages come in we'll be upping that to 3:1, for a shooting speed of around 6000RPM.
If I had to give any advice, it would mostly be that versaplanetary gearboxes with low reductions are wonderful, not only for powering your wheel, but mounting it to your frame. A helpful note, using a CIM adapter on a versaplanetary and gearing it 1:1 (no reduction stages) is a wonderful way to easily and sturdily drive a flywheel with a CIM or Mini-CIM. This setup on a Mini-CIM nets around the same top RPM (~4500) as with our setup mentioned above. See Ri3D Greenhorns for an example of this use case.
I'd suggest using the 775pros (or 775s from Banebots), as opposed to BAG motors, CIMs, or Mini-CIMs, for the higher top RPM and power-to-weight ratio, seeing as a shooting mechanism is very unlikely to torque-stall and burn out the motor during regular operation. However, I'm sure there are ways to make any of those power a successful shooter.
Unread 18-01-2016, 21:10
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
We've stuck with mini-cims our entire prototyping process and have been pleased with the results. I posted a video of said results in Robot Showcase. Our final design incorporates this motor. Actually, almost all our high power motors in the current design are mini-cims, including the drive system.
Unread 18-01-2016, 21:14
Originally Posted by kitare102 View Post
We've so far been pretty successful using 775pros on a 4:1 versaplanetary gearbox with 4" wheels at ~4500RPM (max rpm for this setup). Once the stages come in we'll be upping that to 3:1, for a shooting speed of around 6000RPM..
Reading between the lines, it sounds like you are not planning to control wheel speed, is that right?
Unread 18-01-2016, 21:21
dkavanagh dkavanagh is offline
FRC #0578 (Red Raider Robotics)
Rookie Year: 2015
dkavanagh is an unknown quantity at this point
Been toying with the need for encoder to get consistent speed. Parts for prototype should be here tomorrow, so snowstorm-allowing, we'll get going with a prototype and hopefully find out.
Unread 18-01-2016, 21:22
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Can someone do a quick rundown of plus and minus of each (Mini Cim, Bag and 775 Pro) for shooters thanks.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-01-2016, 21:24
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
At the moment we're planning to use one of these motors:
Unread 18-01-2016, 21:26
CalTran's Avatar
Missouri S&T Senior
Pneumatic punching option, a la 2014? Sick. I like it.
Unread 18-01-2016, 21:28
bEdhEd's Avatar
Hmmmm.... Is this a hint at a catapult? Or maybe a linear puncher?
Unread 18-01-2016, 21:33
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
A miniCIM... In a vex pro ball shifter
It isn't shiny enough.
