Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 18-01-2016, 17:21
Ltwolf20 Ltwolf20 is offline
FRC #4796
Ltwolf20 is an unknown quantity at this point
Unhappy Driver Station Bug
So recently I began using my Macbook Air to use Driver Station using a Windows Parallel. It has been working fine overall, however I keep encountering a bug where I try to change the team number in the Setup section by either clicking the text box or the drop down arrow and I can't interact with Driver Station at all. The graphs and diagnostics still work fine but during this time I cannot click any buttons or change the team number. Has anyone else encountered this problem and is there a possible fix?
Unread 18-01-2016, 17:25
MaestroRoboto's Avatar
MaestroRoboto MaestroRoboto is offline
AKA: Hiren Bhavsar
FLL #0020 (The Rocketeers)
MaestroRoboto has a spectacular aura aboutMaestroRoboto has a spectacular aura about
Re: Driver Station Bug
I encountered this problem over the weekend on a Windows 10 machine. I got the driver station to work after doing an un/reinstall.
01001000 01001001 00100000 00111010 00101001
Unread 18-01-2016, 21:53
This happens when an mDNS call doesn't return. The times I've seen this in the past were due to firewall settings. I have also had reports that stopping the nimdnsResponder service can cause this if it is not running. I was unable to reproduce the issue.
Greg McKaskle
