Go to Post ...your stress reliever is a ziptie with the end cut off so you can pull it straight through. It really works! - Storcky [more]
Unread 18-01-2016, 22:11
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: pic: 8 inch pneumatic wheels
How did you manufacture that hub?
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 18-01-2016, 23:43
Tmeziere's Avatar
Tmeziere Tmeziere is offline
AKA: Tim
FRC #3021 (The Agency)
Team Role: Driver
Tmeziere is an unknown quantity at this point
The hub is two pieces. The first ops of each piece where done on a cnc lathe starting with a piece of raw material 4.25" diameter. They bolt together with four 10-24 bolts. The screw holes where drilled and tapped on a cnc mill, but can easily be done with just a screw driver.
