Go to Post We did the best job we could out there, and unfortunatly we have human limits.. The refs don't catch every penalty, inspectors don't catch every issue, and this year the score keepers won't catch every single ball. - nobrakes8 [more]
  #31   Spotlight this post!
Unread 18-01-2016, 21:06
PurpleInk PurpleInk is offline
Mrs. BoilerMentor
AKA: Betsy Baxter
FRC #1747 (Harrison Boiler Robotics)
PurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant future
Re: [Ri3D] Team Indiana Presents: Veronica
The 3D PDF is ready!
You will need to download it and open it IN ADOBE to view it properly.
Check it out HERE
-Team Indiana
FIRST Team 1741 - Student 2005 - 2007
FIRST Team 1741 - Mentor 2007 - 2012
BoilerMentor Asks Me to Join His Alliance
FIRST Team 1747 - Mentor 2012 - Present
Ri3D Team Indiana - 2015 - Present
  #32   Spotlight this post!
Unread 18-01-2016, 23:45
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Originally Posted by Nathan Streeter View Post
Did you discuss the impact of used balls vs fresh balls elsewhere on a video that we could go back and reference?
How much compression were you getting on your balls? (distance from shooter wheel surface to curved backplate)
Thank you for your insights! :-)
Not sure if it was on video or not--it would be somewhere in the second day.
I know the compression was >1", but I can't be positive on the exact amount (wasn't my subsystem). We did get the arc down to 29 degrees. The shooter also had strips of AM's abrasive green belting on the arc.
Originally Posted by JesseK
Were the stealth wheels able to manage a long-distance shot in such a short acceleration arc? Approximately how much compression was the ball under while in the shot arc?
Trying to get a 4" diameter wheel to get any distance, even with equal wheel edge speeds as larger wheels, has been ... challenging...
After we switched to the short acceleration arc, there wasn't much distance shooting--the arc was always pointed in a direction more conducive to close shooting. Could you do it from a distance? Maybe, if you can get around ball variance issues. We tried shooting from the Outerworks distance, and though we couldn't hit the target due to the angle being too steep, we still got plenty of air.
I can't be sure on the compression. It was at least 1" and had strips of abrasive material on the hood.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
  #33   Spotlight this post!
Unread 23-01-2016, 09:39
kbuford2000 kbuford2000 is offline
FRC #3096
kbuford2000 is an unknown quantity at this point
Hi PurpleINK,
THe PDF that was posted opens as a blank document with the SOLID WORKS statement at the bottom of the document. Do i need a special viewer for this PDF?
Thanks
  #34   Spotlight this post!
Unread 23-01-2016, 11:09
xhantari xhantari is offline
FRC #1339 (Angelbotics)
xhantari is an unknown quantity at this point
Originally Posted by kbuford2000 View Post
Hi PurpleINK,
Thanks
Are you opening it in your web browser, or with Adobe? You have to download it and open it with Adobe reader to be able to enable the 3D content.
  #35   Spotlight this post!
Unread 23-01-2016, 14:54
Mrs. BoilerMentor
AKA: Betsy Baxter
Hi PurpleINK,
Thanks
If you just click the link, the image will display as a blank paper that says Solid Works at the bottom. That is because it 'opens' in google drive which cannot support the 3D format.
At the top of that page, you'll need to click the 'Download' button. It looks like an arrow pointing down towards a line.
Once it has downloaded, simply open it.
I hope this helps!
