Go to Post You do need help. Don't reject offers of assistance from veterans. There are more things you don't know than you think there are. - Alan Anderson [more]
Unread 19-01-2016, 00:14
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Bumper requirement.
We have a chassis configuration that would look like the picture. The corner to the angled in part is 4.5 - 5 ". As per R19 [....If a side is shorter than 8 in., the entire side must be protected by BUMPER....] So then we only need to cover the said part correct and not the angled part inside the opening?
Unread 19-01-2016, 00:23
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Re: Bumper requirement.
The side isn't only 8 inches though. The side is, if I understand correctly, 9-10 inches plus whatever that opening is. Ergo, you need 8 in on each side.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 19-01-2016, 00:28
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I have uploaded an edited version of your image below. The line highlighted in green is defined as a side of your frame perimeter. Because the frame perimeter is defined as the polygon formed by all exterior convex angles on your robot, the side continues through the gap in your robot's frame. Your bumpers as currently configured are illegal unless rectified to match the configuration shown in blue.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 19-01-2016, 00:36
Rookie Year: 2015
Yes I seen the >=8 but doesn't the rule say
"If a side is shorter than 8 in., the entire side must be protected by BUMPER"
This is our debate.
Unread 19-01-2016, 00:42
This is our debate.
The side of the Frame Perimeter.
Here is how to settle the debate: Take a string, stretch it around your frame. That string is your Frame Perimeter. Any point where that string forms a corner must have 8" of bumper on either side, plus a fill-in piece to fill the corner. If the string forms a curve, the entire curve gets a bumper.
I've attached a full-robot sample image--one side of the opening is legal, one is not. Your design is currently on the "not" side of that.
Name:	Frame Perimeter Image.jpg
Unread 19-01-2016, 00:52
Rookie Year: 2015
Its sinking in.... I don't have to like it. We are going to have to rework a few things.
Unread 19-01-2016, 05:39
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Technically isn't the 8" measures from the corner of the robot, not the corner of the bumpers? This would require it to extend an additional ~3.25" in to the gap on each side.
Unread 19-01-2016, 07:22
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Originally Posted by matthewdenny View Post
Technically isn't the 8" measures from the corner of the robot, not the corner of the bumpers? ....
Yes.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 19-01-2016, 10:03
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
This is correct. I should have clarified that in the drawing, but that is why the arrows didn't extend all the way to the end of the bumper.
Unread 19-01-2016, 12:15
Rookie Year: 2015
R26 then states BUMPERS must be supported by the structure/frame of the ROBOT
This would mean the front C-channel must extend in from the corner >=8" correct?
How much of the vertical 5" bumper backup board must be supported by the structure/frame?
Unread 19-01-2016, 12:47
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There are many ways to support it, but the simple version is to have the channel be 8" long. There is no specific amount in the vertical direction that needs to be supported. The main point of the rule is that you can't have the end of the bumper floating in free space. A flat sheet of thin metal that covers the entire back of the bumper also wouldn't count as supported for most inspectors.
My guideline is that if the bumper was not present, you wouldn't be able to bend the frame behind it easily by hand. If you are counting on the bumper to be a structural element of your frame, then it won't pass inspection.
Unread 19-01-2016, 14:18
Rookie Year: 2015
No we would cut the regular c-channel to 8". Seems though we might only have the bottom 1 to 2" in contact with the frame. We will see, just wanted to know if there was a rule we had to pay attention to.
Thanks you all been a huge help
