Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 18-01-2016, 21:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Motor Used for Shooting
Hands down, 775pro!
R.C.
MadTown Robotics Team 1323
Unread 18-01-2016, 23:02
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
We made a prototype 2 wheeled shooter with 6 inch wheels and 2 mini-cims direct drive. For the final design we are going to switch over to the 775pro's with a 3:1 versa Planetary
Unread 18-01-2016, 23:31
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Originally Posted by R.C. View Post
Hands down, 775pro!
Hm. I wonder why you would say that
But in reality, I would have to agree. 775pros have been our best motor to shoot the balls.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 18-01-2016, 23:56
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Reading between the lines, it sounds like you are not planning to control wheel speed, is that right?
Both sides of our shooter have an in-line versaplanetary encoder which allow us to control the speed of each wheel. Funny story, we remembered when we were setting different RPMs for testing that 4500 is the max for our setup because we set the system to 6000 and the when we measured our speed with a tachometer, it never got above that 4500. Hopefully that speed will be achievable with the new gearbox stages.
Unread 19-01-2016, 00:01
R.C.'s Avatar
Not biased at all...
But in all seriousness we used it to test our 6" wheeled shooter and loved the performance. The power per weight is unmatched at this point in time.
R.C.
Unread 19-01-2016, 00:14
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We are using 3:1 versaplanetarys with 775pros on a greenhorn style 2 wheel horizontal variable angle shooter.
Cims and mini Cims do decent at 1:1 bags don't work at all unless you go for a 5:1 or higher gear ratio.
Unread 19-01-2016, 00:42
If you are operating the wheel at max motor speed there is no headroom to do closed-loop control.
So if you have a 775Pro geared at 3:1 and want to control the wheel speed at 6000 RPM you won't have a lot of battery voltage left to work with.
Unread 19-01-2016, 02:53
AKA: Eric
I'm not the one behind the controls for the robot, but I believe we're more interested in using the encoders for 1) making the two sides of the shooter differ by set amount to see how spin will affect trajectory and 2) monitoring when the flywheels get up to speed so that we can move the ball into the shooter the moment it's up to speed.
Unread 19-01-2016, 05:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We're planning to pull our catapult with an AM PG71 (motor is a 9015), taken down another factor of 3.6 (at initial design) with sprockets and #25 chain. The encoder is already in place on the COTS assembly.
We'll probably use another PG-71 (no encoder, just limit switches) for our mechanism to lift the ball over the bumpers and into the launcher.
Roller pickup TBD.
Unread 19-01-2016, 05:45
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Nick.kremer is an unknown quantity at this point
I have seen you posting the same thing in a few other threads. I was wondering if you have a minute to explain/have a link to a thread that explains how operating voltage is tied to using control loops, to someone who knows very little about such things?
Check out Team 3512's Website!
Like us on Facebook!
Unread 19-01-2016, 07:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The control works by varying the voltage supplied to the motor. The motor controllers cannot put out a higher voltage than they take in from the battery. Without getting into PID theory, essentially if it's going too slow, the voltage is increased; if it's going too fast, the voltage is decreased. If you're running the motor at top speed (giving it full voltage), you can only adjust down. Far better to have your nominal operating speed at say 75% of top speed, especially later in the match when the battery voltage is reduced.
Unread 19-01-2016, 07:56
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
We have been using bb550 motors on versa planetary 3:1 gearboxes with a four inch wheel. It has been working great for us. We have used these motors in the past with great success and I am surprised i haven't seen anybody else using these motors.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 19-01-2016, 08:03
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Our team has tested both the miniCIMs and the CIM's. We are using two CIM's to "launch" the boulder. Good luck to all teams this year!
Originally Posted by CalTran View Post
Just curious as to what motors people are using to siege the opposing towers with. With the unlimited-ness of non-CIM motors, what are people going for?
Team member 2004-2008
Team mentor 2008-20XX
http://www.team1708.com/
"Education is a powerful tool. Always use it to better someone else's life"
Unread 19-01-2016, 09:05
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
We're also looking at using a 775pro at a 3:1 but I'm having trouble figuring out how to attach a longer shaft to the VersaPlanetary Gearbox shaft.
I figure in order to gain efficiency it would be better to drive the shooter wheels directly from the gearbox, without adding a second set of gears, belt/pulley or sprocket/chain set-up. We don't have a lathe, so is our only option to not directly drive the shooter wheel?
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 19-01-2016, 10:25
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Originally Posted by Boltman View Post
Can someone do a quick rundown of plus and minus of each (Mini Cim, Bag and 775 Pro) for shooters thanks.
For a shooter it really doesn't matter too much. The main thing that matters is your RPM and compression, I'm not convinced torque has a large impact on the shot as much as it has on spin up time / slow down after a ball is shot (which doesn't matter in this game). You want to get the wheels going at a specific repeatable speed to get an accurate shot - generally between 3000-8000 RPM with a 4" wheel(s) and depending on the distance / angle etc.
The advantage to a Mini CIM is that you can direct drive and be at around the right RPM, the disadvantage is that you can't really go any faster than free speed unless you gear up - which is silly. The Bag, 775, or 550 all have high free speeds and require some gearing down, but a versa planetary box makes that really easy. 550s are a little weird this year since you can't get them from VP or AM. Also consider packaging and where your motor / shooter will live inside the robot.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
