Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 19-01-2016, 07:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Motor Used for Shooting
Originally Posted by Nick.kremer View Post
I have seen you posting the same thing in a few other threads. I was wondering if you have a minute to explain/have a link to a thread that explains how operating voltage is tied to using control loops, to someone who knows very little about such things?
The control works by varying the voltage supplied to the motor. The motor controllers cannot put out a higher voltage than they take in from the battery. Without getting into PID theory, essentially if it's going too slow, the voltage is increased; if it's going too fast, the voltage is decreased. If you're running the motor at top speed (giving it full voltage), you can only adjust down. Far better to have your nominal operating speed at say 75% of top speed, especially later in the match when the battery voltage is reduced.
